Old March 14th 2012, 11:13
Originally Posted by scardeep View Post
What are you going to do with intercooler? That tail was your “logo” in my eyes Looking forward for updates!
No worries Scardeep: Intercooler stays there!
Not much updates yet, will be several weeks before parts are machined.
Old April 7th 2012, 15:53
1200 turbo engine is now up and running again and with a FK7 and 1,4 ratio rockers.
Its "a bit" on the wild side for a 1200cc engine, but rocks from 3K rpm onwards.
First time on the wastegate (leaking BOV though) and up to 6200 rpm
https://www.youtube.com/watch?v=wNkOkUwHHK8
Dynoday in Germany (near Hamburg) is on the 28th april...
Old April 8th 2012, 10:40
I'll definetly be there! I'm really looking forward to finally meeting you after all these years!
Old May 2nd 2012, 11:15
Got a feature in a general tuning mag
Old May 2nd 2012, 12:25
SWEET. You are very deserving of some press.
Old May 2nd 2012, 12:54
chug_A_bug's Avatar
very NICE... well Deserved
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old May 2nd 2012, 14:13
owdlvr's Avatar
owdlvr owdlvr is offline
Noice!
...Got a link to the magazine website, wouldn't mind seeing if I can get a copy onto my iPad.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old May 2nd 2012, 15:02
Congratulations, about time you got some press recognition!
Old May 2nd 2012, 15:12
Tnx fellows!
Dave, this is their web-site:
http://www.autoentuning.nl/
http://www.autoentuning.nl/?p=3928
Cover of the issue and the content page (as far as I am allowed to post):
Old May 3rd 2012, 04:14
Congratulations Wally! I agree,well deserved and long overdue! Why is car in race magazine? Because race car
Old May 3rd 2012, 21:12
Very cool Wally! Congrats!
Old May 5th 2012, 16:02
Cheers!
In the meantime, I started on the revamp of the 2,2 engine beginning with the new central cooling lay-out:
Old June 3rd 2012, 02:40
effvee effvee is offline
Cheers!
Walter, why the change in shrouds? I thought you liked the horizontal setup better. Was there a difference in CFM of the two?
Old June 3rd 2012, 05:38
Yes, I like the horizontal set-up A LOT! However, at very high RPM, it doesn't always stay on when the ecu activates the Rev-cut or fuel-cut.
It has shown to be good for 7700 RPM easy, but not combined with sudden soft- or hard-cuts in the ignition.
Air distribution is naturally very good with the horizontal set-up, but with the arrival of this centrally positioned cooling system from MSS with his shroud, I think there is a better chance cooling will be close to evenly spread with this one as well.
CFM (total air moved) is dependant on a lot of other things. Pulley size has a huge part there and the Riechert pulley is much larger (172mm?) then the vertical set-ups (most are 145mm as is this one, also to clear the DS pump), so you know which one will move more air...
Also the fans are different. 12 blade fans displace less air then the older 11-blades, so thats different as well.
Your question about CU.ft/min sort of suggests that more CFM cools better, which is still questionable. Lots of variables.
So, ...my track use with very high rpm with lots of iginition cuts more or less lead me to a vertical set-up again, but I think only by actually using the system and seeing what it does or doen not do on a certain engine, can give an idea of how well something works.
Old May 7th 2012, 05:07
paul_f's Avatar
paul_f paul_f is offline
How did you get on with the 1200 turbo?
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
