The info is all there in the log though ![]() EDIT: does everybody 'get' the log? (in what you see?). The log adds data and therefore puts new info at the left in front of what was already there, so you need to watch it in such that the car runs from the right hand side to the left. Boost and INJ% (= IDC) rise when I floor it and throttle gets over 90% (100%=WOT). The x-axis is in seconds (time), so the log part you see here is from about 7 minutes ago after I shut it down back home. /EDIT Do you also see the IDC (injector duty cycle) climb to over 80% at the end of the run at about 6000 rpm? I am a little (too) rich maybe so a little gain in IDC room can probably be made, but I am running out of injector pretty soon (again...) Quote:
But how much boost you can run is not always that decisive on making power: Case in point: I needed to take out a lot of timing with the smaller turbine of the IHI turbo (which choked on my engine I can now probably safely conclude). Depending how much timing I can bring back (which is dancing with the devil as well), will determine more how much more power I will be able make. I f you can run a fair amount of boost AND you don't have to retard timing a lot, then that says something about the efficiency of the combo. At least, that is my experience so far ![]() I think I am going to make an apppointment with the dyno already :-)) Last edited by Wally; October 29th 2009 at 04:13. |
Ahh now I see the air temp - thanks!
Inlet temp plays a key role for that,which also dictates how far you advance your timing and where in your rpm band your max boost will start.What is the MB (Lambda?) and PM (Timing?) on the vertical line in the graph mean? Last edited by 70Turbobug; October 29th 2009 at 12:27. |
Great to see the new turbo is working for you, and thanks for the clarification on how to read the logs.
I've copied the image to my desktop so I can review it in detail and then ask some questions What size are your injectors again ? I'm now thinking my 57 LB/hr (599cc/min) are now too small Sandeep |
![]() I now run the 60 or 63 lbs Siemens injectors. Said to be 660 cc/min at 3 bar or 45psi fuelpressure, but I have upped the fuel press. in the meantime to 3,5 bar. Rolling road dyno is booked for saturday morning early. Little bit too soon, but later wasn't possible or too late for me... I hope I can get the boost regulation dialed in again on time and tune for it. Will be stressed for time, but very curieus what she will do on the dyno. BTW If you indeed study the plot closely, you can see that at around 5800-6000 rpm, the lambda gets a little higher for half a second and that the closed-loop immediately corrects this by adding fuel, which makes the IDC go up there at almost that same very instant! The Bosch/Innovate are very quick to react and the DTA closed loop function does too. It all shows in that very spot. I have now added some more lambda filter, so that will smoothen the curve a bit more I hope and relex the closed loop corrections a bit ;-) Last edited by Wally; October 29th 2009 at 13:13. |
Some of the abbriviations fell away because I put the line exactly in the spot where 1 bar boost has been reached, so you all could see what the sensors read there, especially the rpm, which makes a nice bridge tou your q.:
![]() and PM the remains of RPM ![]() ![]() so hopefully you now see that 202 (1,02 bar boost) is reached at 3535 RPM
![]() Result: 350 hp! at 6500 rpm with close to 300 hp at the rear wheels ![]() ![]() ![]() Torque: max at 420Nm or 310 ft.lbs at 5200 rpm. I fiddled somewhat with fuel correction and look what I did in the other run, but up top we made some gains (just 10 hp): Flywheel hp and torque of both runs: ![]() Rear wheel hp:
WAY TO GO!!!!
MMMMMMMMMM... I Can't stop drooling.
Do you have extra head studs on your engine for the boost? |
sweet
Great job Wally!!
Nope, just good ones (ARP) but it only has 16 psi at 6000-6500, so its not excessive boost that created these hp numbers
![]() And on a 103mm bore, which is said to not even seal in n/a aplications... And cast alu cylinders, stock VW type4 crank and stock rods. I count at least another 3 myths busted
[/QUOTE]I wonder what my 2.8 build would put out turbo'ed?Hmmmm. |
Good looking numbers! hows the seat of the pants feel between the different turbos, any noticable difference besides lag?
Awesome #'s Wally !
Congratulations on your 350hp aircooled daily driver ![]() Sandeep |
| Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
