Hi Wally
Looking good. A few people I know ran boost boxes and things didn't work as well as would be expected, the extra volume slowed reaction to everything connected to it. Where do you take your signal for your wastegate from? Been told by serious turbo tuners to take it after the throttle plate, that way it reacts to actual motor pressure not the pressure in the between the turbo & throttle plate.
I would be happy to redirect, but its the first time I learn of this. Thanks Steve, Walter |
Wally, ever try a solid center clutch disk?
'72 super '65 bus '52 split |
Nope, not even ever any semi-metallic pad...
While waiting for the disk to arrive, I cut some polycarbonate ('lexan') sheets for the side windows.
I thought they were lighter than the 1,5kg I saved per side window (2,45 to 0,95kg), but its weight up high, so it will benefit more in the corners I suppose.
As the 6-puck has not arrived yet and I need to run on sunday, I have reinstalled the old organic disk. Flywheel has been resurfaced and machined down so the pressure plate now has some more pre-load. Fingers are now perfectly horizontal. This should give some better holding power by itself and it did
![]() Boost has again been tuned to 14.5 psi and oh boy what a rush once 3000 rpm gets passed ![]() From the datalog I could see that at about 2850 rpm there is 0.5 bar or 7 psi boost and at 3500 rpm the full 14.5 psi is reached. The engine easily runs up towards 7000 rpm, but I want to stay before that for a little bit longer as I am not sure where max hp will be. Coming saturday there is a local mobile rolling road dyno (more or less just across the street for me) so I will try to enter the car there. I only ran the full boost in 2nd and 3rd as to not risk a premature clutch burn-out but that went well. So fingers crossed for saturday when the dyno run will be done in 4th. Very curieus what it will get, providing the clutch holds .
| Currently Active Users Viewing This Thread: 15 (0 members and 15 guests) | |
