#451
Tnx Ninja,
Now I know what I wanted to ask you Wally..where did get those thick gaskets for your manifolds and throttlebodies?
#453
Mc Gyver style
#454
Really?! That´s pretty cool! I would have never thought of that! I hope your wife wasn´t too hard on you for cutting a chunk out her kitchen top
#455
Great upgrades Wally. All appropriate for a 400 hp " 20 min Ring " beetle
![]() Sandeep |
#456
Finally I got all parts to install the Sard FPR:
![]() ![]() Tnx Sandeep; spring 2010 is already behind us, how is your engine comming along? |
#457
Cool! What did set your fuel pressure at? Will you have change your maps or can the DTA adapt and still use the current maps?
#458
Wally will you leave you fuel pressure gauge in place or will you remove it?
I have the same one, but it says to only use it for setup only and to not drive with it fitted on the box |
#459
Mark: it was about 3,5 bar, but the closed loop fuel control of the DTA ecu can easily make little fuel changes if fuel presure will be different
![]() Quote:
![]() Not sure yet if I will try it out on longer runs, but I might just remove it and plug the hole after the fuel pressure is original again. Good eye! Machined flywheel for the twin disk set-up just before it went in:
#460
Reinstalling engine pics:
![]() ![]() ![]() ![]() ![]() I wanted to connect a port from the header to measure turbo beack pressure. From am idea of a good friend of mine, I used an old brake hose to saw off the coupling and just used a regular copper-alloy brake line to connect it to:
#461
looks great as always man... btw your dog is Sweet looking
![]() Chris.
#462
I see a new addition. Have you had trouble with the fan belt jumping off Walter?
Paul |
#463
Hopefully this will keep it on, even in 'abnormal' conditions. Yep, love my english springer spaniel. We have always had those for as long as I can remember ;-) Engine runs again and the twin disk seems to engage pretty easy and gentle. Much to my surprise I must admit. It only rattles from the center plate like an old Ducati when the clutch is depressed. Oh, well ![]() Tomorrow test drive to work I was thinking
#464
Test drive went fine: clutch engages really not different than the former one, which is great!
Backpressure is about 50% over boost pressure, which gives great spool but seems a little too restrictive for this 2.2 liter engine. I need a bigger turbo! (again.. )Next weekend is Spa Francorchamp 'Le Bug show'! Can't wait to finally be allowed to drive the whole track. |
#465
Good to see you have overcome the clutch issue. That set up should get the power down. Have a good trip to Spa. I hope to see an in-car video of a lap of Spa.
| Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
