Old September 12th 2010, 14:18
Fast65 Fast65 is offline
My 65
my cars not german look or Cal Look but has bits of both some of you may have seen my car on other forums so fingers crossed not to boring lol
Specs so far
Engine
2332 turbo, efi, NOS, water injected, charge cooled T1
Transmission
T1 pro street
Wheels
OG Bruners
Brakes
944 Turbo with 928 4 pots
Interior
70s 911 tombstones and a few gauges
ive done all the work on the car myself starting from this
Ok i purchased this bug for my wife in 2007 and looked like this
i wanted her to stay like this but claire wanted me to lower her so she then looked like this
so that was it the car has been messed with so i took this out
and put this in
2332cc CB high roof case, Scat crank 84mm, CB H beam rods, 94mm B+P, Total seal rings, Engle FK10 cam, Scat lifters, Berg chromoly pushrods, Jaycee pushrod tubes, Scat 1.4 rockers, A1 1 3/4 Sidewinder exhaust ceramic header and stainless back box Vband clamp , Deep sump, Jeff Denham welded heads 44 x 37 valves heavily reworked with matching manifolds, Berg linkage, Fuel injection kit-CB throttle bodies, DTA .
Gearbox by Cogbox close 1,2 and 3 gears tall 4th for cruising all welded gears heavy duty side plate, superdiff Sway away short race axles.
then to stop i made these fit
so all is going well then i find loads of the ginger stuff bottom of door, some in the wings and heater channels. I found some NOS 65 doors and got hold of some day mouldings wings and painted them then started on the channels
now looks like this
im fitting a G50 over the winter so watch this space
cheers andy
