Not really: that point was just where the cursor was at that moment. More random therefore. Boost was about 1.0 bar at 4K, then climbing further to just over 1.7 bar at around 5K, then tapering to 1,5 at 6K and further down to 1,4 bar at 7K.
On the road, in 4th, 1 bar is reached at 3600 rpm if its not too hot outside. Just follow the horizontal lines on the y-axis at the right. The scale is there. If you can read plots, it shouldn't be too hard to see what is reached when ![]() Quote:
I use the Berg dual springs with Ti retainers. I will try to install my CB650's over winter. That will sort that out.@Sandeep: I think every motor is different and maybe I have restrictions elsewhere, but boost is tapering despite my EBC set at closed-loop... so I suspect my 8cm² turbine (~0,63-ish I think) is just too small for these kind of hp. My back pressure readings kinda confimed this imo. For an even bigger engine like your comming 2413cc, I would surely get the 0,82 A/R if you had free choice. You may loose some spool as opposed to the 0,63, but you already got that covered by the 200cc's more you have over mine... I also looked heavily at what Subaru owners use (hence my DOM3 I got off a us Suby owner) and this combined with my current experience, I would surely get the 82 for your 2413cc. Our engines are just more responsive by themselves somehow I think. You don't want to know what my next turbo/turbine size will be...
I'll keep the .82 in mind before I take the .63 out of its new packaging
![]() My guess on your next turbo is a minimum of a GT35R (GT3582) or somewhere there abouts ... 400 to 650 HP on a minimum 2.0l. You got to 400hp quickly with this build so I'm thinking ~500hp minimum is your next goal ![]() Sandeep |
Its ~0.78 A/R iirc and saves a lot of weight on the right side of the car...![]() Quote:
Its not anything like you mention though... ![]() When (if?) it gets here, I'll sure let you know/show you. It is meant for after an engine upgrade tbh, but it would be interesting to try it on the 2,2 first and see the difference later on the bigger engine (which will take a year or two probably..). |
Just finally got confirmation that the new turbo had been produced and a small batch was shipped from the Borg-Warner plant to Full-Race.com which just shipped one out to me
![]() ![]() ![]() How big? Its a T4 Twin-scroll with a compressor in between a 35R and a 40R, so its fairly big ![]() Also got a second hand, but unused waste-gate from evil bay, but need a second one because of the twin-scroll lay-out.
Hey wally you finally going to do the twin scroll turbo setup. Glad you are because i want to use a twin scroll Holset on my 1835cc engine once i build it. |
| Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
