#721
Yeah, allthough visually it doesn't really looks to be any smaller...:
![]() ![]() Didn't take more than a hour to exchange them ![]() New feed pump (Carter 100gallon/h) also installed. Attending a dyno day on the 12th march, so fingers crossed it now all works.. |
#722
Man....we have to wait almost 2 weeks? That sucks
#723
Ultra cool.
#724
Just went for some better fuel just across the border today and had the opportunity to tune the maps again and check out the new feed pump, higher fuel pressure setting and the other turbine housing.
All worked VERY well ![]() Boost threshold for my own 1 bar boost reference went down 300rpm to about 4030 rpm ![]() Boost and fuel was also very stable so tuning was much more easy. All set for dyno day ![]() |
#725
Wally, a quick question: Are you using the stock beetle voltage regulator or the riechert (porsche) one? I'm trying to build a 1.7 type4 for this season, and I was wondering if I could just use the stock regulator, in it's original position, and wire the porsche alternator just like the orig. vw one was.
www.vw1303s.com |
#726
What regulator is a topic on its own. Get the right one, type4's also work, but not always as good as could be. I use an electronic one.
Anyways, Got my pics from Julian today Yeah!: Thanks to Julian Hunt for making these: http://www.julianhunt.net ![]() ![]() and some of my buddy Franc his car: ![]() ![]() |
#727
yeah, you're right.. I was just feeling a bit lazy, and wanted to leave all the wiring alone. But I'll use the regulator that came with the riechert kit.
Oh, and great pics!!!
www.vw1303s.com |
#728
Nice Pics! What is your friend Franc running in his bug?
#729
Type 4 2056cc 44x38, Web86, Remmele exhaust, DTA E48.
Stock gearbox, which then of course broke on the line at Santa Pod on the 2nd run after some expert advice on how to launch from 'some' DKR member ![]() Car is very, very nicely done, much nicer then mine and is very light and very good roadholding (I drove it last year).\ BTW, I have bought a piece of (cage) pipe to re-stiffen the right-hand side gearbox fork after I needed to remove one leg of the Cup-strebe because of the turbo's 4" air intake piping.. |
#730
![]() Quote:
what are the dimensions of the wheels?
vw standar 1973 vw 1303 sunroof - Automatic Stick Shift 1974 vw variant squareback 1968 VW PARAGUAY |
#731
On my car, on drag race set-up as seen above (black wheels), the fronts rims are 3,5x17 size and rears are 7,5x15 iirc.
#732
I understand, these wheels are safe with the car super lightweight
excuse my English, just use the translator hehe!
#733
The gold centered wheels are for the road and circuit (18") The car is super heavy by the way, not lightweight at all ![]() |
#734
Got bored today and downloaded the log from the 1,8 bar (1,8-1,9 ~26.5-28 psi actually) boost 'mishap':
Apperently the alu cylinders can survive this boost! Who would have thought that? ![]() |
#735
Cool! Am I reading this correctly? 4703rpm and the throttleposition is WOT / 100%? The other 2 graphs are going downwards after that except the throttle-it remained opened? Sorry...I´m still learning how to read these things.Or ist that just what the peak was?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
Thread Tools | |
Display Modes | |
