#1141
Wally I told you in the past that since you are a pioneer in type4 turbocharged engines you should do it professionally. Nice work by the way.
VW 1303s 1975 (German Look) VW 1300 1964 (Rally Car) LAND ROVER DEFENDER 90 V8 BMW E30 318i CONVERTIBLE 1992 Italian Toys - GERMAN WAR MACHINES ![]() WRC is for boys - GROUP B WAS FOR MEN |
#1142
There´s no money in it really if you consider the time and hassle involved with parts.The only way to go is to make as many parts as you can yourself which requires a whole park of expensive machines and tools.Nowadays that´s the only way you can stay in business and build quality engines.Also 80% of the aircooled community are cheap and are not willing to pay the price for quality custom made parts.An engine like Wally´s would have to sell for about 10-15K at least in order to be able to live off of it owning a business.
#1143
Thanks for the complement, but I like it better as a hobby. I also have more joy in the tuning of engines then building them tbh.
EFI tuning engines would be a fun job though ;-) I have a wild idea to try out next season BTW :-) |
#1144
Some new ingredients to better chase the Race-taxi at Spa this year
#1145
Sweet. Grip is good.
#1146
Nice! Toyo R888? How's the engine coming along?
#1147
i had good fun trying to chase the race taxi round lydden hill a few weeks ago.
#1148
Surely you will be faster than the race taxi Wally?!
http://www.ricola.co.uk |
#1149
I doubt that very much. He's ace at taking corners. I have much less confidence. Hopefully the new tire will help some with confidence
![]() Engine long block is sort of ready Mark, shroud is 'fixed' again ![]() ![]() Flywheel and clutch are finally ready too, so hopefully hang the block in the car this WE ![]()
#1150
I love that clutch! Do you have a hydraulic throw-out bearing? Looks like you´ll be back on the road soon! It will be interessting to see how all these new mods will perform!
#1151
Walter, why the change in shrouds? I thought you liked the horizontal setup better. Was there a difference in CFM of the two?
#1152
I would say the fan belt is one reason...
#1153
It has shown to be good for 7700 RPM easy, but not combined with sudden soft- or hard-cuts in the ignition. Air distribution is naturally very good with the horizontal set-up, but with the arrival of this centrally positioned cooling system from MSS with his shroud, I think there is a better chance cooling will be close to evenly spread with this one as well. CFM (total air moved) is dependant on a lot of other things. Pulley size has a huge part there and the Riechert pulley is much larger (172mm?) then the vertical set-ups (most are 145mm as is this one, also to clear the DS pump), so you know which one will move more air... Also the fans are different. 12 blade fans displace less air then the older 11-blades, so thats different as well. Your question about CU.ft/min sort of suggests that more CFM cools better, which is still questionable. Lots of variables. So, ...my track use with very high rpm with lots of iginition cuts more or less lead me to a vertical set-up again, but I think only by actually using the system and seeing what it does or doen not do on a certain engine, can give an idea of how well something works. |
#1154
looking good.
#1155
X Two for that, ive come across cases where the motor was overcooled and needed the smaller pulleys to bring it back into 'the zone', and it picked up A LOT of power.
| Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
