Old March 9th 2021, 12:53
Blizzard's Avatar
Blizzard Blizzard is offline
Thats correct. 96mm. Biral cylinders, JE pistons with 22mm. piston pins.
Old March 11th 2021, 18:00
Blizzard's Avatar
Ignition setup
123 ignition tune+ distributor, see link for more info.
https://123ignition.com/product/tuneplus-4-r-v-v/
silicone spark plug wires made to length
MSD Blaster-2 coil (mounted on firewall next to CSP crankcase vent box)
Old March 17th 2021, 05:10
Blizzard's Avatar
Some photos of the 1971cc Type-4 build.
I started with removing the old oil galley plugs and tapping them for NPT plugs.
A NOS cranckshaft that I had ballanced with a 200mm. flywheel
cc'ed the CU-heads
Set deck height on new Mahle flat top piston and cylinder set
Because I used 1700cc rockers in combination with 8mm. swivel ball valve adjustment screws (I will come back to this later),
I had to make new longer pushrods for the correct rocker geometry.
To make it easier to turn the camshaft/crank I used lighter pressure springs.
And made my own adjustable pushrod
After testing and installing the correct jets in the DRLA carburators
I was the proud owner/builder of a smooth running type-4
https://i.imgur.com/eAs18TT.mp4
The reason that I replaced the 1971cc type-4 with the 1904cc type-1 is it
left a smoke screen worthy of a bond car after only running for 100 kilometers.
The cause of the failure was a locknut that came loose of one of the swivel ball valve adjustment screws,
I am afraid to use these again. I am 100% sure I tightend all the locknuts.
With the locknuts loose the adjustment screws are very loose inside the rockers and can move side to side.
Is there enybody else who had this happen??
The nut became stuck between a rocker and the cylinderhead, breaking a piece out of the bottom of the head.
Resulting in a massive oil leak on to the exhaust
Old March 17th 2021, 05:17
Blizzard's Avatar
I rebuild it with new CJ heads before I started with the 2056cc. in januari.
It is now ready to test start and install and hopefully this time run longer than 100 kilometers.
Old March 17th 2021, 05:26
Blizzard's Avatar
Used my CAD skills to make a Rear Engine Tin to fit the Porsche-Style Cooling.
Cardbord And Duct tape.
The bolts will replaced and I will make a better looking one out of thicker aluminium.
I made this very quick so I could drive the car.
Old March 17th 2021, 22:20
flat flat is offline
Sweet CAD!
Looks like an awesome engine, hope it all goes well!
www.vdubengineering.com
Old March 19th 2021, 06:03
Blizzard's Avatar
Thanks!!
Sneak peek,
Front mounted RS style oilcooler in Remmele Motorsport front bumper.
