Old April 2nd 2003, 19:31
paul_f's Avatar
paul_f paul_f is offline
Originally posted by Pillow
Yes, but just little things.
First you will need the MC mounting adapter that Wolfgang Int sells. Usually used to fit Baywindow MCs to split busses.
This needs to be modified slightly to fit, the id of the smaller part of the centre bore needs to be increased in diameter by at least 2.1mm, mine was increase by 2.3mm as the outer surface had not been machined and was not perfectly true.
Having the bigger bore allowed my to modify the rubber boot supplied with the kit and fit it.
Regards
Paul
