Old May 6th 2003, 17:51
944 track on the front
been doing a bunch of reading on a 944 conversion for my standard. i am mainly interested in the track widening in the rear. i did not see an answer to this question though...do the 994NA or 944T brakes on the front widen the track? if so, how much?
Old May 7th 2003, 03:35
SprintStar's Avatar
SprintStar SprintStar is offline
Yes, the 944 NA brakes do widen the front track as well. I don't have exact numbers, but after fitting them to my '73 Super, the 15" x 6" Cookie Cutters don't fit under the stock fenders no more....
I think it's roughly about 1/2 to an inch per side.... Eyeballing it...
Sprint.
Old May 7th 2003, 15:28
thanks. i know when i went from drums to ghia discs on my standard it adds 1/4" per side. anyone else know for sure on 944NA and/or 951?
Old May 8th 2003, 00:51
chigger chigger is offline
Mine only increases the front 1/4 inch for the Ghia hubs and the thickness of the early 944 rotor about 3/16 inch. It was the best I could do at the time. since then I can do it with only 1/4 inch increase.
Old May 8th 2003, 04:32
SprintStar's Avatar
Err.. So you are using Ghia hubs and rotors with 944 calipers?
Sprint.
Old May 12th 2003, 21:00
Superman
The 944 conversion, on a Super, widens the track by 10mm per side. I have no idea on a Standard.
