Old May 7th 2003, 08:37
Angelo Amato's Avatar
Talking Finally finished my own rear disc coversion !
Porsche brakes are nice but a bit OTT for most applications. Also I challenged myself to see if I could pull of this conversion myself ! And to produce it cheaper
Car:- 1973 Type 3 Fastback
Rear brake parts used:-
Type 3 Hubs (used)
Merc rear discs (used)
Mk4 Golf GTI Calipers (alloy ones) with pads and flexi pipes (brand new - bow available in plenty used).
Mk2 Golf flexi to rigid brake line brackets
Mk2 Golf GTI hand brake cables
Type 3 hand brake cables
Custom made caliper brackets
1. Type 3 hubs dia. turned down to fit into merc disc, redrilled and fitted with wheel studs to suit (i'm running 5x112mm PCD merc fitment wheels)
2. Custom brakets made to fit in place of existing rear backplate (i.e. between irs arm and bearing cover)
3. caliper fitted to bracket with Golf caliper carrier and bolts.
4. Mk2 Golf flexi to rigid brake line brackets sourced to secure pipes on top of irs arm.
5. Hybrid hand brake cable formed from shorted MK2 GTI outers and type 3 inners (drum end cut off and new nipple crimped on)
RESULT ?
After being a bit sceptical about the whole project (as in 'why did i ever start it' scenario ! ) It's turned out real good. All parts are good and servicable and should perform as OE. No road test has been done (parts have just been assembled)
The handbrake cable could do with being 1" longer as overall length was reduced because of cuttting off the type 3 end - may have new cables made up otherwise (as i found a local cable place that'll do anything ! BRILLIANT !!! )
I will post plenty of pics soon, I'll be dismantling the setup (only done one side for now!) to fully weld brackets.
Any questions/comments are welcome
Cheers,
Angelo
Type 3 Fastback
Old May 7th 2003, 09:10
Thumbs up
Excellent Angelo !
Would you be interested in submitting a tech article on the subject ?
Thanks,
Old May 7th 2003, 10:33
Sure no problem !
Will pull together some text and pics.
Will let you know !
Angelo
Type 3 Fastback
Old May 7th 2003, 18:13
Type 3 Fastback
Old May 21st 2003, 06:38
67type3's Avatar
67type3 67type3 is offline
hello.
job well done. i own a 67type3 squareback and want to convert all my drums into disc soon, but i do not have the parts needed, not the donor car. is there a bolt-on option available?
thanks.
Old May 21st 2003, 18:47
MattKab's Avatar
MattKab MattKab is offline
Thumbs up
Good effort la'
Old May 22nd 2003, 13:23
Nice Angelo!
Especially since your set-up will save a lot of unsprung weigth also as opposed to the 944 set-up.
Walter
Old May 29th 2003, 10:32
MdR's Avatar
MdR MdR is offline
Well done that man.
Wonderful the feeling you get when it all works out in the end.
How's the pedal travel with the new rear hydraulics?
+44 (0)7812 167547
martinandsonjaATf2sDOTcom
Old May 29th 2003, 15:20
just in the process of final install.
mocked up one side, now the other is done and fully welded.
all painted and reay to go on, only prob I had was a little distortion on when welded, nufin a lump hammer couldn't solve !
Seems ok now, will fit proper and connect hydraulics.
Angelo
More pics to come soon!
Type 3 Fastback
Old May 30th 2003, 08:42
MdR's Avatar
MdR MdR is offline
Re: just in the process of final install.
That was the problem I had when I did the front link pin disc conversion on our '58 ghia.
I ended up getting my caliper mount milled square on all the faces.
Martin
+44 (0)7812 167547
Old May 25th 2009, 04:51
blitzvw's Avatar
blitzvw blitzvw is offline
Nice article Angelo.
I'm planning the same modification for my Fastback, using 411 rear hubs, New Beetle discs and calipers, and a custom caliper bracket...
Using MK4 Jetta steelies with the 5x100 PCD, so it would be directly compatible with my wheels
Blitzem with Type 4 power
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
