Old July 30th 2003, 10:47
MattKab's Avatar
MattKab MattKab is offline
The trackrod ends will fit into the new bush from above the steering arm, tapered stud pointing down.
Offer the new bush to the tapered stud on your trackrod, so you can determine where the castlenut/splitpin hole will be once they're installed. You may have to modify them (in length) slightly- I did, tho' mine were bought in plain packaging from a trader at a VW show.
'hope that helps,
Matt
