Old August 21st 2003, 15:02
Stuart Stuart is offline
rear coilovers
A firm called Remmele has a beautiful setup for the rear. It's about 700 euro overhere in Europe. As the dollar is low on this moment I guess that it costs +- $ 700 + and shipping. The kit contains al the hardware and you don't have to cut in your car. An other advantage is that the normal shocks will not bold to the alloy arms because at the bottom the porsche bolt is M 14 as for the beetle M12. Further more is the beetle shock a little out of line when bolted to the alloy arms. The setup from Remmele does not have this problem because it has unibal connections.
