Go Back   GermanLook Forums > General > Members Rides
Old September 10th 2002, 22:25
sorry for the delay. we don't get warned when an email is left regarding your car.
anyway, the car was chopped by a previous owner. it had fiero GT seats with custom made brackets. i did a bunch of research before i figured i was never going to have the answers i needed. i ordered a set of momo seats with no brackets and figured i would work mounting and height from there.
as luck would have it, the momo seat fit right on the brackets i had. way cool. the only down side is that these brackets bolt to the pan. if an accident is bad enough, i imagine they could rip right through. i plan to use some metal strips to run under the pan from bolt to bolt to try and strengthen it. and i have 4-point harnesses to hold me in place better.
hope this helps. i can do some measuring if you need it. basically any standard seat height will work. you just have to have brackets that are low enough.
