I think there is a problem with code using the database of the old forum to log in. I have to talk to Sandeep about this.
This might take a while. Alex |
Avatar?
Cant edit avatar either!!
Xzenor |
The avatar needs to have a certain pixel size. What is the error message you are seeing?
Alex |
I'm looking at the code today ...
Sandeep |
Hope to have this fixed for Wednesday morning. Sandeep |
Hello,
Well, I thought it was time to put an avatar in my profile, but it doesn't work for me! I don't even have a "use custom avatar" button! It sounds I've the same "problem" Xzenor mentioned. Maybe it's just me having my fingers in a cyberknot !Cheers, Richard |
Click on "User CP" upper left corner. Go to "Edit Avatar" on the left menu bar.
Select "Use custom avatar" and upload you avatar from a web site or local hard drive. Also in the "Edit Options" on the left menu bar of your User CP make sure that you have "Show Avatar" enabled. Alex |
No fault code....
I cant change the little dot on the "do not use avatar" screen. It doesnt do anything when I click on it.
Xzenor |
If you use that the do not use avatar dot will go away. Works for me. Alex |
Yes....
I dont Understand why it doesnt work for me. Ever since we got this new forum it hasnt worked for me. I even tried making a new user ID and password....same problem. I cant even get into "Member Profile" with my new one. I was able to with my old one......but not no more.
Xzenor |
The member profile on the main page does not work. The new forum uses different authentication encryption.
We still have to figure this out. Does the avatar now work? Just be patient....no one can update their members ride at the moment. We are working on it. Alex |
