I think for that you will need a bearing spacer(vw spindle). Boygenius is getting a group buy together in the group buy forum on this site.
Porsche 944 spindles have about 1 1/2 to 2 degrees more positive camber
than the stock VW spindle, this is where the problem lies (in the design). There are several things that you can do to over come this problem. The first thing to try is Topline's kit called Camber + that will give you and additional 6mm of camber adjustment. If that doesn't do it then you'll need to slot the upper hold of the strut to spindle mount (see a Golf or 944 strut for an example of how to do it). Also, if the spindle can be clearanced to allow the strut to seat farther into it (see pic attached). See my website www.superbeetlesonly.com for more/other Super help. Last edited by Superman; February 28th 2004 at 01:13. |
i´ve the camber problem but i am using 944 TURBO 1987 spindles. They have more positive camber like a 944 NA
