Old March 1st 2004, 03:10
Make a new brake rod from a long bolt(cut the head offand round it with a grinder). You will still be able to use a jam nut.
Old March 1st 2004, 08:09
i mentioned that to jake while he was over and he warned heavily against that due to wear and breaking. i figure a grade 8 bolt would be solid enough, but he didn't feel it would. he recommended welding onto the existing rod and reshaping. i have no clue. thoughts?
Old March 1st 2004, 09:16
I would think a correct size socket head cap bolt that was cut down would be okay, those are pretty hard and come in about any size you could want.
63 356b time capsule
948 project
Old March 1st 2004, 09:36
I would think a grade 8 would work, remeber that 8.8 metric is a grade 5 SAE and a 10.0 is a grade 8 SAE. You will have to get it very round and smooth. I would cut it off with the ziz-wheel and then put you drill in a vice and chuck the bolt in it and use the drill as a lathe(locked at a medium speed) and round it with a file then smooth it with sandpaper.
Old March 1st 2004, 14:34
boygenius's Avatar
Have you tried adjusting the spring plates. They are supposed to be adjustable for ride height aren't they.
I would go with a high grade bolt for now and replace it later if it bothers you.
Old March 1st 2004, 14:39
will look into those bolt options. i can run it as is for now. still plenty of pedal.
genius, the spring plates aren't going to make up this difference. will take some pics when i get home. i now have dropped spindles on the front and it is about 2" higher than the rear. my header is about 2" off the ground. i was WAY off. seems stock preload would have been the way to go. best guess anyway...and it better be right since i only have time for one more crack at this.
Old March 1st 2004, 14:52
boygenius's Avatar
Do you have beetle torsion bars or the thicker 944 torsion bars???
