Old March 23rd 2004, 00:49
fast70's Avatar
fast70 fast70 is offline
Jake,
If you don't mind me asking, what modifications did you do to the 911 shroud to make it run cooler? Any info would be great. If this is priviliged information, you don't have to tell me or if you could send me an email. This is just for my use only.
Thanks for the help,
fast70
Old March 25th 2004, 00:31
Massive Type IV's Avatar
Drilled holes in the shroud!!!
Jake Raby
Old March 26th 2004, 00:59
fast70's Avatar
Can you be a little more specific?
Old April 1st 2004, 20:46
cnavarro's Avatar
cnavarro cnavarro is offline
Nickies would most definately resolve cooling, sealing, and longevity issues. We have customers running our 90.5 and 92mm Nickies, under boost, both of which use registers of a 94mm cima/mahle, so the walls are extra thick!
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old May 2nd 2004, 19:30
blue4400 blue4400 is offline
Now I'm even more confused. I though the porsche fan cools the cyclinders and heads better?? I know it uses a little more power, but that was fine by me as long as it cooled better. Which is the best way to go about cooling the engine better??
Old May 2nd 2004, 20:24
cnavarro's Avatar
A 911 fan just delivers more cooling at lower rpms than a stock fan, but there reaches a limit where you just can't push any more air over the cylinders. The same net effect can be reached by changing your pulley ratio and keeping your stock cooling setup. On the other hand, by putting on aluminum cylinders, you can dissipate more heat, which makes better use of the limited airflow that can be pushed past the cylinders.
Charles Navarro
LN Engineering
Old May 2nd 2004, 20:34
boygenius's Avatar
Here are a few things to consider. The 911 fan was designed to cool a 6 cylinder engine and not a 4 cylinder engine. It pushes more cfm than can flow past the cylinders and heads. You can slow the fan speed down to correct the cfm for a 4 cylinder but then you run the risk of under charging the battery. The other thing to consider is that the 911 kit shrouds don't have any directional vanes inside them to direct the air to where it needs to be. One side of the engine may get more air than the other side of the engine and thus cause a temperture difference. Since it takes more power to run you need to give the engine more throttle while driving to maintain speed so the engine is under more load and therefore running hotter. An engines operating tempurture is infuenced by more than the cooling system used. It is influenced by compression ratio, cam choice, carb jetting, fuel grade, ect...
Old May 5th 2004, 12:10
I'm in the same boat as Fast70
I was reading the article on Germanlook.com, Blowing for a living, reading thread left me a bit confused. I'm building a 2110 turbo motor and a little worried about the cooling especially with the heat and traffic in South Florida. I’m installing a bigger oil cooler with a fan and I though the Porsche fan was the way to go. What would you recommend for me? What would you do for yourself? I already have the Porsche fan and alternator. I also have the vane that goes mounted on the back side of the fan to distribute the air better. I don’t think it will fit but I was thinking of modifying it to fit. Some of the kits I’ve seen can get a bit pricey, so I’ve been looking at the Autocraft or Sharpbuilt kit. I think the Sharpbuilt is better in my opinion. What kit do you think is best or better for the money?
Thanks in Advance for your help
