Bruce, Are you sure? Think about it as simply jacking the car up and down. If you jack the car up (the suspension arm goes down) you get positive camber and if you lower the car down (the suspension arm goes up) you get negative camber.... Mike
Modification is a form of art. Performanceghia is still alive and kicking... |
Positive Mike (pun intended)
As the stock suspension articulates, the pivot point is not the TA's inner pivot. It is also not the center of the torsion bar at the spring plate. It is along a line drawn between these two points. Because this line is not parallel to the torsion bar but tilted back as it extends from the spring plate's axis to the center of the car, the TA goes negative camber when the TA goes up. Now loosen the 3 bolts between the TA and SP. The new axis is along a line from where the 3 bolts are to the TA's inner pivot. This line is tilted opposite of the one above, so therefore camber changes are opposite. |
Bruce,
Point taken... for some reason I was thinking that it was the inner leg which the bolts were on Going from the outer TA being longer to being shorter ... as in pivot point... yes it reverses the action. Chers Mike Quote:
AWESOME information in this thread. I'm foregoing the camber boxes for now ... no time to complete it but will perform the TA/SP alignment mentioned.
I will reort back with my findings in about 2 weeks ![]() Sandeep |
Bruce you da man
Bruce, reading your posts I realize that you’re a lot smarter than I. So, I’d like to bounce a couple of things off of you to see if they make sense. First of all, the way I see it, the reason that camber changes as the TA moves up and down is the angle of the pivot axis relative to the center line of the car. That axis runs thru the center of the inner pivot bolt to the intersection of the spring plate with the center line of the torsion bar. If the pivot axis was perpendicular with the center line on the car, there would be no change in camber. If it were parallel, there would be extreme changes in camber. I think this agrees with what you have said.
As far as moving the inner pivot up, I like this idea because it would provide anti-squat for lowered cars. But it seems to me that in doing so you would be increasing positive camber unless you also moved up the outer pivot. Since my car is lowered I’m thinking of raising the pivot points (inner and outer). I’m using narrowed TA’s and spring-over-coils so this shouldn’t be too hard to do. What do you think? Also, looking at the picture above of the “BugPerformance red tube chassis beetle” where the outer pivot is not on the same axis as the inner pivot, doesn’t this setup cause unnecessary stress in the suspension components? |
Ron, I appeared to have you fooled. It took me a long time to figure that out. I first saw how the relationship works about 5 years ago. A guy I know didn't install the 3rd bolt attaching the TA to the SP, and the rear of his TAs tilted up causing lots of +ve camber. I tilted it down and got -ve camber. At that time I didn't understand why this happened, I just knew the relationship.
Then when Mike posted the opposite a couple of nights ago, I again thought of why and it finally came to me. In your first paragraph, you have it exactly right. When the pivot axis is parallel to the torsion bar there is no camber change. A perfect example is the front suspension on a torsion bar Bug. This design exhibits absolutely no camber changes of the susp relative to the car's chassis. Unfortunately body roll causes the tire to be positive camber relative to the ground. If you move the inner pivot up, how does this give you "anti-squat"? Squat as I know it is caused when there is weight transfer, like when you dump the clutch. How can moving the pivot up prevent weight transfer? If you do move it up you get radical positive camber. I have a friend who converted his 54 swing axle pan to IRS by welding in the pivot points. By mistake they got the pivots in too low. Its not much, but it caused horrible negative camber. Even after flipping the TAs left to right, he still had negative camber. If your chassis is an original IRS one, raising the inner pivot would be difficult. Raising both inner and outer would be even more difficult. I don't see the point. The geometry change wouldn't be any different from stock. In looking at the red tube chassis suspension, I think the long link (that replaces the spring plates) is that long for convenience. It had to be that long to reach the chassis. Just a guess. Being so long is bad for camber change. Small changes in ride height will cause massive camber changes. It doesn't look like the car is finished, so he probably doesn't know what's going to happen. I think you are right. Its going to be hell on the inner rubber pivots. Worse if he's got urethane. If you look at the stock pivot bolt, its axis, if extended, would probably intersect with the center of the torsion bar at the spring plate. Thus there is no binding. But move that outer pivot that far forward, you're in trouble. |
Anti-squat
Bruce, if the TA pivot axis is higher than the center of the rear wheels, the force transferred from the wheels to the TA tends to cause the TA to rotate about the pivot axis in a clockwise direction on the driver’s side and counter-clockwise on the passenger side. The result is a lifting force at the pivot points, which works to reduce squat. If the pivot axis is lower than the center of the wheel, the opposite is true and the car will have more of a tendency to squat excessively under acceleration. Have you noticed at the drag races how the entire car is “lifted” under acceleration? This is caused by the lift bars. If you crawled under one of those cars you would see that the rear of the lift bars are lower that the front. Therefore, under acceleration, the wheels are causing the lift bars to rotate such that the entire chassis is lifted upward. The Bug’s TA can act like a lift bar.
With the stock Bug chassis, the rear of the TA is lower than the front as it should be -- no problem. However, if you lower the rear of the car much, the rear of the TA will be higher than the front, and handling will suffer. I have seen some people argue that squat isn’t all bad since it helps with weight transfer. I think they are getting confused, thinking that squat some how aids weight transfer. The amount of weight transfer is dependent on the height of the cars center of gravity, the higher the better. When a chassis squats, the center of gravity is lowered. Anyway I hope this all makes sense to you, if not please let me know. |
Camber Adjustment
I have / \ and want | | Thanks |
Yes the mod did work. You have to rotate the rear of the trailing arm up in relation to the springplate.
Sandeep |
Spring Plate Mods
The bolt closest to the torsion housing is threaded into the trialing arm and the bolt does not stick through the inboard spring plate. The other three bolts go in trough the inboard spring plate, through the trailing arm and out past the outboard spring plate where there is a spring washer and a nut. This brings up two questions: Which bolt do you want to use as the pivot point for the TA to rotate about? Why can't you slot the TA holes vertically instead of over sizing the holes in the spring plates so you have movement in two axis? (There's not much meat around the rear spring plate slots.) |
-When you lower rear IRS suspension, tires get negative camber. -For even tire wear and good handling performance, you want to get rear tires near zero camber. -When you put those two statements together you get: After lowering your IRS rear suspension you need de-cambering, right? -One way of de-cambering is to move the inner pivots of trailing arms upwards. -This can be done with a camber-box familiar from Porsches, or maybe by fabricating a DIY mounting, higher than the original one. -Again we couple the two earlier statements and get a question that I`m interested of: If you move the inner IRS mount upwards the same amount that you have lowered your rear suspension, do you get stock camber??? Justin |
and all though I havn't lowered my car yet, even with irs should you get a little bit of the neg camber. The way I'm picturing this is; where ever the axis of rotation is to draw a mental perpendicular radius or moment arm to the point in question, then to following the arm as it rotations under a constant distance. help please
Rip H. Van Winkle "The Ultimate Sleeper" |
Hey Bruce!
You should make an article about how to adjust the rear camber, like in your previous posts here, and have it posted in Germanlook.com technical section!! I think it would be a great addition because when the rest of us (me) get our wide rear wheels, we can just point and click in the Tech Articles instead of searching through the forums! Thanks for the great info everybody!! Clint
Coming Soon! 86mm X 90.5mm German Look Bad *** VW Hopefully Soon!! Back home in Port Orchard, and saving for the Bug |
This has been a good read and helpful.I am in the middle of this dilema at the moment.I have done an IRS conversion on my pan using jigs I made years back,and have used on 2 previous conversions with no issues.This time I have also done a major mod on the pan-cut the frame horns off and moved them out 50mm each side,to fit in an auto trans from a Type3.When I got it all back together,I had serious neg camber issues,so pulled it all apart and rechecked everything to see if there was distortion of anything because of all the welding.I suspected the outer ends of the torsion bar tubes may have pulled up,but using a straight edge across the outer body attaching spots and measuring the difference between the 2 pans at the centre of the tube-the auto pan was 0.5mm different-so that's not the problem.I put it all back together and tried moving the adjustment of the 3 bolts,and got it slightly better,so it looks like the small die grinder is going to get a work out.I did spend some serious time thinking about making the inner pivots adjustable,a bit of work,but would be easier on this one because the inner threaded bits are now exposed on my pan.
IRS camber adjustment is made simple by installing the Kerscher rear anti-roll bar bolts.
A spanner (open ended wrench) is used on a hex bolt to make the adjustment. I can't find a picture of the bolt so I will try to discribe it.. The forwardmost springplate bolt is substituted. The hole in the springplate is enlarged to a circle that is the same diameter as the first shoulder. The new bolt then rotates in the sprigplate. The 2nd shoulder is eccentric and 12mm, threaded to take a lock-nut to secure the TA from the outside. The head of the bolt is in the middle The other side of the same bolt is shouldered 10mm and locates the anti-roll bar drop-link. Offers +ve to -ve camber adjustment. Has zero effect on toe adjustment. Very trick. Matt
'79 Karmann, Nrburgring or bust... Last edited by MattKab; February 6th 2006 at 16:15. |
