Old October 12th 2002, 14:48
kiwivw kiwivw is offline
944 IRS coil-overs
Hi All,
I've been looking for a while now for coil-over for the 951 rear trailing arms i have. I would really like to have a set that has a helper spring setup, since i will be removing the torsion bars as part fo the changes needed to install a 915 trans (cutting through the middle section of the torsion tube).
Any suggestions?
I notice Alex uses the Bilstein/Eibach coilovers, with what appear to be helper springs.
Any help would be great.
Cheers
Craig
Cheers
Craig.
