Old August 6th 2002, 11:35
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Where can I get the Red 9 kit info?
Where can I get information on the Red 9 kit?
My main question for the coil-over front kit was how well did it work. I understand the weight issue was important to you as your kit relieved quite a bit of weight up front.
I want the kit for the adjustability of ride height, as well as the ability to change spring rates to suit my needs versus sticking with stock rate torsion leafs or the 20% stiffer ones that are available aftermarket.
Thanks in advance.
Kevin J Hale
