Old May 4th 2004, 11:08
Give Lanner a call @ vdubcustoms. He'll set you up and advise as to what he needs.
Pete,
I've already greased the bearings and installed the dust cap and the setup is mounted on the bug so can't take pics of the spindle nut. Check the brake galleries and you'll see a pic of my first setup (944T). The hub assembly is the same and I used an aftermarket spindle nut and got all threads on except maybe one ? I found my original spindle nuts and they measure about 4mm thinner than the aftermarket ones, so I used those instead and I get all threads on the spindle nut to engage.
Hope that helps.
