Old May 13th 2004, 14:36
Bruce2 Bruce2 is offline
When I switched to 944 spring plates, I used the stock VW spring plate covers. I had to cut down the outer rubber grommet that is bonded to the spring plate. The diameter was the same as VW, it was just too long. Once I cut it down until it was the same as the VW one, I installed everything using thick washers between the cover and the shocktower. The thickness of these spacers was close to the same thickness as a spring plate. Thinking back though, all I had to do was grind down the rubber grommet that much more and not use the spacer.
