You would think that having it in and having one more night off that I would have been driving the hell out of it today. Well I must report that it is still over at Kevin's waiting to put the deck-lid back on and wire up the alternator. I spent all of today swapping the old engine and transaxle in Ryan's bug for the new engine and transaxle that I had waiting for him. It was his birthday and I needed to get the new drive-line in as his gift. I'm whipped after 2 engine swaps and a trans swap in one weekend. I will fire Ryan's up for break-in in the morning, then go get the black bug finished and drive it. Then take a nap and go to work. I will have to install the MSD rev-limiter and do some engine bay clean-up work next weekend to be ready for HoD.
Mike
My new user name, Mikey for some reason, I havn't liked this name since I made it. Sorry for any problems... Mike |
My son's engine spund great, we did the break-in run on it this morning and then tuned the carbs. But the clutch will not disengage. I fought with it for hours. Looks like I will have to pull the engine back out and I haven't gone over to finish up my car. I'm not a happy camper right now. And I have to go back to work tonight.
bummer dude. I know all about bad luck like that.
If I may give advice, from personal experiance, be sure to check everything when you get to pull the engine out. The first time we pulled it out, it looked like just the throwout bearing, then the second time we pulled the engine out and the clutch disk was bent. It seems when we put the engine in we pushed a little too hard and bent the disk, and it was a 4 puck disk so that didn't help any. I hope some of our mistakes will help you not make the same. Mike
Well I pulled the engine back out and found that the spline shaft on the trans had some light rust on it and it didn't let the disc float so it was jamed against the flywheel. It dose fine now. I need to make one more adjustment to the clutch cable and tune the carbs again and my son will have his car on the road again. I did take it for a quick run and it will do a nice burn-out and has some good power. It's a 1641 with scat C-35 cam, 8.5 to 1, Weber 34 ICT's and a 4 into 1 with a quiet pack. Then it is back to my car.
