  #20
Old June 16th 2004, 03:28
Chris Percival's Avatar
Have a look in the suspension galleries. On the first page, 8 pictures in, is picture of a device that can eliminate the torsion bars and enable you to use a coil over shock as the only rear suspension. It basically fits on where the springplate fits on to the tiorsion bar tube, l and allow the trailing arm to pivot like normal. To get spring rates you would ideally need to get the car weighed on all four corners and then have someone knowegable work it all out for you..
