Old July 1st 2004, 09:30
Good luck Adrian!
Nick
Old July 1st 2004, 10:17
vujade's Avatar
vujade vujade is offline
hope all goes well
WinterJam 2010
Old July 1st 2004, 18:04
Cool,,,,It will be nice to see it on the road again.
Old July 1st 2004, 22:21
boygenius's Avatar
Good luck. You can do it. :agree:
Old July 2nd 2004, 09:13
very cool. do let us know. have you checked in with panelfantasic. he did a hell of a lot of custom fab, but he may have some of the answers you seek on shock mount and such.
Old July 2nd 2004, 10:00
Panelfantastic's Avatar
The problem is Adrian is applying sanity to his fabrication !
Mine is so far outside of stock, that nothing applies. I definately understand his fear with the re-engineering... I've been taking longer and longer "short trips" trying to shake mine down and get everything dialed in. A good bit of the interieor is done now so it's more comfortable and I can focus on engine and suspension sounds more... still every little squeak gives me chest pain.
Adrian, of course any help I can give...just shout. :agree:
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old July 2nd 2004, 12:21
Pillow's Avatar
Pillow Pillow is offline
Life is almost good!!!
I took her out today to go to the allignment shop (Butler Tire in Marietta, best rack and operator in the area IMHO). Very sketchy on the way to the shop as the front and rear were out, but after some tweaking she runs straight now. The technician (Gene) was at first not happy to do it as he thought it would be a rust ball with all kinds of stuck bolts... Then he looked underneath and was pleased to see all new parts He went from aprehensive to happy to see a custom change that was well excecuted. Not bragging at all, but he told me that it was really nice and that I almost had it alligned alright to begin with in the rear. No control arm changes needed or spring plate changes needed! The front was way off due to putting in new tie rods, but easy to adjust.
The tricky part is adjusting the Solex 40P11 carbs as they are way off and running lean, very lean. So enough typing - time to get wrenching!
It feels great to be behind the wheel again! Also the 944 brakes all around are insane!!! Wow can this bus stop, barely touch the pedal.
Overall I am pleased with the conversion so far. The gearing may be too high though as I can run 55MPH in 3rd at 3500RPM... At that rate I will never see 4th!
Thanks for the support!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
