Old July 12th 2004, 18:06
super vw super vw is offline
Well for min work room around the cars... i would have to say 3 feet, i have about 3 feet to work around my project (shelving and benches take up lots of space) and its about the min i would want to work in, its fine if things get picked up and things stay un cluttered.. but once you get things all torn apart and clutter starts the build up, it cam become a little tight and a mess to walk/work around.
I think you should try and build it so you have around 5-6 feet around the car.
For work benches, make some ones that have a crapy(cheap top) and some that are nicer (like a lamanate or somthing) aswell as a 1/4 steel toped area for welding/ banging....ect. the cheap top ones make replacable so when they get all messed up you can easily replace it, this kind of top i like when making things, its great not to have to worry about messing up your counters whne the going gets tough...or whatever.
Cabinets should be large enough to store tall paint cans and other autochemicals and be strurdy and well ancored to the walls. get some beefy hinges to, dont skimp on hinges!
Make it so you have storage under your counter tops, maybe even some that have no shelf and only doors and no bottoms so you can slide a shop vac in witout having to lift it..ect
Dont forget a drill press, bench grinder, and maybe other large tools you use... at least i like to have all that as i like to make stuff, but im not sure what you do so...
MAYBE even make a "pit" under one of the bays if you dot get a lift, this would make under car work easy. i know a friend who did this to his concrete slab floor... it was a good 8 feet long.
Well thats all i can think of now,
Later,
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old July 13th 2004, 03:10
miller's Avatar
miller miller is offline
me and my dad have been workin on our shop for about a year now. its 20x20 and its basically a green house with a reflective top instead of plexi. The setup cost 700 and the concrete cost 700. its got plenty of room. One important thing about a shop is you gotta have lots of ventalation and lots of light. Their is nothing worse then coming into a shop and having stagnet air with the smell of gear oil and brake clean. Storage space is also a biggie and for me its a nessasary to have a nice sound system so I can blast some tallica while a grind and weld away.
67ghia, 2.3T mid engine conversion, tube frame dbl a-arm, rx7 brakes, currently in parts collection/bodywork stages.
Old August 9th 2004, 13:27
ShApE's Avatar
ShApE ShApE is offline
we just finished ours its like 30x34 i think, all of the upstairs is storage, plugs - 1,10s, 2,20s. whole house fan, and carport.
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 76 cadillac seville (me & dad's) =-
-= 2002 toyota sequoia (brother's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old August 9th 2004, 14:56
nice shape. looks like someone is getting ready to take it over as a rehersal space though .
i like the carport add-on idea. not sure it will fly with my HOA, but i like the idea.
Old August 9th 2004, 23:01
SuperRSi's Avatar
SuperRSi SuperRSi is offline
OH, I thought that was the stereo install.
Randy
