Old July 16th 2004, 18:22
Massive Type IV's Avatar
The 2270 C is the most efficient engine I build. That is just ONE curve that has been there for over two years.
Keep in mind I have over 60 proven combos for the 2270C!
The 2270 "Roller" engine will make reliable power similar to a 2316 with the same tuning as a standard 2270.
The first roller cam is being designed now, and the engine is just waiting on the cam.
Jake Raby
Old July 18th 2004, 05:41
Mysticle31 Mysticle31 is offline
Well unless I go with a corvair engine..lol. I'm saving up for your type 4. Just have to figure out if I should build a beat/blow up a cheapie type 1 first.
How high does 3rd on some of these VW's go? I was riding in my friends BMW 325is and he went to pass a tuck on the freeway, and (can't drop it into third without hiting rev limiter) and droped it in 4th. If I was in my jetta. I can take 3rd up to 101 (gear chart), drop it into third and pass just about anything quickly (on the track GSR's, Newer vr6 jettas, Mustang GT's, could never catch it. Never had any vets, nsx, bikes..) I like having really nice gearing. I don't know how 4 speeds do it. Drop it into 3rd, 2nd? Power/torque acessable for quick quick acceleration from 0-100mph (ha ha just a nice point to stop) and 13.8 in the quarter. Gutted car. I'd love to make a slightly faster, better accelerating car then the jetta. At least match it.
Old July 19th 2004, 16:27
My 914 with stock gearing will turn 110 in 3rd gear at 7700 RPM.. Thats with 181 BHP and a rev range to 8,300 RPM.. It idles stock and doesn't sound built till you tap the throttle.
Jake Raby
Old July 19th 2004, 17:03
"Tap the throttle" LOL.... When do you ever "Tap the throttle" in that thing.
That 2316 is the sickest sounding, quickest reving air-cooled engine I have ever heard. It does have a nice smooth idle that will fool you into thinking it is tame. But I can say first hand that it is VERY ill tempered and sounds like it belongs on the Road Atlanta track when you open the taps.
Old July 19th 2004, 23:50
And next it gets Nickies and a Roller cam set up- Thats automatically a boost to over 200 ponies with no other changes made to the engine..
Jake Raby
Old July 20th 2004, 02:07
These revver engines are $$. I'd like to have a good ole cast iron 2270 that could do it. I like the WIDE torque. But I also like the advantage of being able to sit in lower gears for longer then the other guy giving me the multiplication.
Jake, You've kinda been following along. What to do you sugest? (Dont' need anything WOOW! just 150, 160HP. 180 Max, or should I say. Max 10:1 HP per pound in a full mullholland 1302 superbeetle with 944 stuff.
I'm conserned that stock 1st gear in these VW's is going to be too short and useless.. (that's what jake uses in his trannys)?
Old July 20th 2004, 03:01
The engine in my 914 is a standard 2316 Annihilator.. It makes 152 lb/ft of torque at just 2,000 RPM. Thats good enough to roast the tires any time.. This engine was the first of its kind and so far has been the weakest one I have built.
First is not rendered totally useless, its good for bad *** burnouts! I have an option of an aftermarket mainshaft, but it adds 600.00 to the cost of the tranny. Then we can run whatevcer gears deemed necessary by the dyno plots.
You tell me where you want the power and I combine the math with knowledge and past engines performance and make it exactly as you desire- thats the beauty of non standard combinations- and what you are paying me for..
Its all in the combo!
I'd say you need a 9.5:1 2316 with one broad *** power range and a flat torque curve- nuttin to it, just open the old wallet and slide the engine in!
Jake Raby
Old July 20th 2004, 16:35
LOL again. of course when you tap that one you are at 7k in the blink of an eye...actually quicker.
