Old July 20th 2004, 04:27
Was an eaasy fitment, just requires bolts with nuts as it isn't threaded like the steel bug m/c. Just a bit of bending of the hard lines and the switch fitted in a T. If I remember correctly, one of the front connections was very close to the tunnel side so it would be easier to fit that one before you tighten it all up fully to give you some movement.
Rich
Old July 22nd 2004, 05:56
Jeza Jeza is offline
Rich and anyone else how has fitted a 944 MC to a beetle / aircooled VW.
How did you get around dealing with the remote reservoir. I thought it was just a case of using the VW fittings in the 944 MC, but the 944 rubber bungs ID is too big and the rubber bungs from the VW OD is too small for the 944 MC.
Is it just a case of fitting new rubber bungs?
Cheers
Jeremy
1302 RAt "GermanLook"
Old July 23rd 2004, 06:50
Right everybody I've found the answer.
It turns out that orignial German MC's have small diameter plastic connector fittings and small rubber bungs.
After market ones have larger ones that are the same size as the ones used for the 944 MC.
These people have both:
Small
http://www.bughaus.com/master_cylind..._113611153.htm
and large
http://www.bughaus.com/master_cylind...113611153C.htm
And an image of the large connecting pipe, that I believe will fit the rubber bungs on the 944 mc once the reservoir is removed.
Cheers all
Jeremy
Old July 23rd 2004, 12:06
super vw super vw is offline
cool, i have a new MC (1303 unit) but i think its aftermarket SO i might be in luck when i got with a 944 MC.
So you have the 944 MC in hand correct?
When you get it all working, tell us how it works!
BTW whats the part number of the 944 MC you have?
Thanks !!
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old July 24th 2004, 02:46
Jonathan
Not sure what the part number is - there aren't any part number like numbers that I can see on it. But it is the "ate" item.
I'll let you know when its in with the results.
At the moment I'm planning to separate out the front lines (there is 2 front line ports in the 944 mc). I'll use a plug in one side of the front T piece and run one new front line to one side and adjust the old front line to the other side.
The rear is lengthed with a T piece to use the pressure brake light switch and a short line to the new mc port - same as every one else.
Also an update on the plastic remote reservoir fittings. I had a lot of trouble tracking these down. None of the brake shops could help. I eventually found some in an old big BMW (7 series? from 70's?) at pick a part. So if you end up stuck then try the BMW parts department.
Cheers
Jeremy
