Boygenius - what size is your 911 master cylinder.
Comments have been made before that the 944 brakes work as a system and although they came off a front engined car using the single pot calipers with the 19mm VW MC makes it even more front biased. From memory the 911 MC has no variation in the front and rear diameters to make up for the ratio of the 944 fronts (huge 54mm) vs the rears (36mm). Shad Laws made some comments in this thread that are very relevant to this discussion. http://www.germanlook.com/Forums/showthread.php?t=2183 I'm am slowly getting the 944 MC in so I will let you know what that feels like when its working. Cheers Jeremy
1302 RAt "GermanLook" |
Jeremy,
That old post of Shad is indeed very informative and gives us the possibility to put some ratio numbers to our 'feel'. There is one thing that doesn't seem to add up with Shad's calculations though: Using his front/rear bias ratio calculation, a bigger front cup diameter in your m/c, would yield a more rear biased set-up!? To stay with the title of this thread: 'that doesn't seem right' I can't figure this out yet as to why or what I am missing here...? BTW, I'am running now the N/A 944 rear disks on my square (has stock 42mm front cup caliper diameter), which would give a F/R ratio of 1,36. It brakes great, but feels just not as powerfull as my former 1303 with the stock 40mm front cup caliper diameter disk and rear 944 N/A, which gave a 1,23 F/R ratio, but that 1.23 ratio may be on the edge in wet conditions. Because of the square d², a little variation in diameter gives quite a different result in the ratio! All this leads me to believe that between 1.30 and 1.35 should be about 'right'. Last edited by Wally; August 10th 2004 at 02:55. |
I also ran my beetle with the stock fronts and 944 rears (stock mc) and it brake quite unusually being so rear biased. I imagine you would get away with this most of the time, but my main concern is the differing way they would react when pushed, ie the rears would remain very cool and responsive while the fronts would get very hot and possibly fade (non vented rotor and small pad area in comparison to the rear). The 944 brakes with the 944 MC gives a ratio of 1.41, which I reckon will probably work quite nicely. Cheers Jeremy PS have you done brake performance comparisons or is it just a feel thing when you mention your 1303's powerful brakes?
i.e. : 944 fronts: (54mm caliper cup diameter / 23 mm front m/c cup diameter)²= 5.51 944 rears: (36mm rear caliper cup / 19.06 mm rear m/c cup diameter)²= 3.57 F/R ratio would then be 1.54 With a 21/19 m/c the ratio would be even higher at (54/21)² / (36/19)² = 1.85. THATS the point I a trying to make in this equation: The bigger the front cup of the m/c, the more REAR biased the set-up gets!!!! Therefore, 180 degrees from my beliefs before, to get a more rear biased set-up from the stock front setten-up 944 brake system, you DO NOT install the stepped m/c the other way around: i.e. 19mm side to the front and the 21/23mm side to the back. That would worsen the problem. The above holds only true of course IF Shads formula is correct (and 'knewing' Shad, he is quite an educated guy (even then), so I must really believe him) Jeremy, I am realy curious what your or others thoughts are about my above 'conclusion'. True or false? This would also explain the enormous front biased'ness' of my current 944 turbo Cup brake set-up on my 1303 SB with the stock 19/19 m/c ! I think I need the biggest step m/c (23/19?) I can find and maybe additionally a bit smaller front calipers or a front propotioning valve (if possible). Quote:
Greetings, Walter Last edited by Wally; August 10th 2004 at 07:57. |
You have hit the nail on the head. Now all we need to do is to spread the word, as I think this is where a lot of people get confused and go wrong. My 944 MC however is definately a 23mm one as it is cast into the body. Actually 23.86 as they are imperial measures which should give me a good front to rear bias (although I don't know where I got the figure above?) Quote:
http://www.wilwood.com/products/Peda...fmbp/index.asp Quote:
Cheers Jeremy
Yeah, I did several emerency stops with my car then, both dry and in the wet and the fronts always (just) locked up first! A friend of mine with exactly the same set-up (stock VW front disks, 944 n/a rear and stock m/c) but in a 1300 ('68) model and a 2,7 ltr type 4 engine took it to the circuit and reported that on braking hard and steering into a corner, the rear did lock up first. Now that is a very extreme situation, but shows it really is depending what you do with the car that dictates how you want to set it up! Thanks Jeremy, Walter |
Front: 44,0 mm and 36,0 mm (radial mounted 928S alike) Back: 30,0 and 28,0 mm With a 944 n/a 23,81/19,05 (which is even more accurate if the bores are indeed 15/16" and 12/16"), that would give a ratio of 1,23 which is low, but similar to my old 03 which had 1,26 and braked like a boat achor Already saw one on ebay Greetings, Walter |
As I had mentioned earlier, I am leaning on using the Wilwood product line, instead of the 944 MC.
They have a 1-1/16" Tandem Master Cylinder Part # 260-4893 Dimensions and specifications for this master cylinder are as follows: Piston Diameter 1-1/16 inch, which is equal to 26.98 or 27mm Fluid Displacement 1.20 Cubic Inches Stroke Movement 1.35 inch Bias Split 69% Front, 31% Rear Given these dimensions, can anyone “guesstimate” if it would be in the ballpark. I would imagine using a proportioning valve for the front. But I am still learning.. Based on earlier readings I would think that the stroke and amount of fluid would be enough to move the 944 N/A single calipers in the front and back. Thoughts, or comments appreciated? But based on the front to rear ratio, it would seem like to high 2.2:1. Alex
78 Vert, In pieces and on hold also a 73 Saloon, currently being built.. |
Walter did you do the calculations of your current cup set up (with the 19mm Bug MC) as a comparison? Cheers Jeremy
Figured I'd chime in again..
Looking for another option to get bias right. As it has been mentioned there may be some advantage to running mulit pot pistons. That being said... I have been researching the Wilwood Line of Calipers. There Forged Dynalite's with 1.75 inch pistons are made for different size rotors. Can't remember size of the N/A 944 but from a quick glance this morning they looked like 1". I say this because I have been looking for Mulitpiston options that were inexpensive for my WRX, which sees the track. For my particular application, only a bracket needs to be made. Which is where the trial and error as well as some engineering come into play. The mounting method via bracket could be used with the 944 spindles to possible create a nice set up. For the WRX this enables me to use 16in wheels and clear my stock rims. Thought that this could be another option.. I can machine a bracket but need to find out where to do it.. Getting the dimmensions will be trial and error but for about 125 a caliper, could not hurt. Any thoughts.. haven't looked at the rear yet, but its probably a bracket away.. Not sure what type of metal to use.. i.e what grade steal or aluminum (sp) any thoughts.. I have heard of alumin. brackets braking..
http://www.clubvw.org.au/porsche_brake_photos.htm Cheers Jeremy
