Old September 6th 2004, 13:11
Vincent's Avatar
Vincent Vincent is offline
hey congrats on getting the pics uploaded... ok 1st off dont remove the windows untill you have the new rubber to replace the old with. If you do then you bus will not be drivable and you may break the glass... this is from first hand experance with my 65 i had. Ok i would grind down all the rust i could and then sand the rest and get some primer and shoot it all one color at least that way it will start to look better. BTW most GL tend to be monochromatic ie one color so when you get ready for paint look around at diffrent colors you like. My self i like silver and every car i have ever owned is silver or ends up silver. you said you were still in highschool? Try taking a body shop class and see if they will let you work on your bus as part of your projects for school. I had a few friends in HS that did this and over there senior year redid there bugs and painted them in Shop class. Good luck
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
