Old January 18th 2005, 17:12
Pillow's Avatar
Pillow Pillow is offline
I stand corrected after doing the math. The standard 944 N/A setup seems to be a good bias as compared with the early 911s 1.60 bias.
Just for the record 911 SCs (20.64 master with 48/42 calipers) had a 1.31 bias BUT used a rear preasure regulator that cut in at 33 bar. From "Porsche 911 Performance Handbook" by Bruce Anderson page 216.
... More to come, but I am thinking a 944 MC (23/20) with 911 "A" caliper front (48mm) and 944 rears (36mm) might work well with a 1.34 bias. Very rear heavy for a streeter though I think..?
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old January 18th 2005, 17:22
Jeza Jeza is offline
Adrian
That combo sounds almost perfect
I thought the CB kit was very similar in bias
Keep us informed with how you get on.
Cheers
Jeremy
1302 RAt "GermanLook"
Old January 18th 2005, 17:31
Thanks,
Be sure to be accurate with your calculation since AFAIK, 23/20 944 MC doesn't exist. In europe all I've come across is 23/19...
Also my 944 rear isn't 36mm, but 38mm IIRC
Differences in diameter quickly add up in a cross section (surface)!
Good luck,
Walter
Old January 18th 2005, 18:27
MattKab's Avatar
MattKab MattKab is offline
'23' is more like '24' from 25.4(15/16") = 23.81mm, you knew that..
Matt
Old January 18th 2005, 22:16
Pillow's Avatar
Good feedback guys!
As for the 944 MC I got this one off a '87 944S model and it is cast into it "23" on one side and "20" on the other. Maybe this is different than the early 944 '83-'86 MCs?
So the 23 is really 23.81, Jess that really does throw the numbers a bit
Okay so the 19 or 20 will realy be either 19.05mm (12/16") or 20.64mm (13/16").
I went and measured the single piston 944 calipers (again from a 1987 944S) and I found them to be fairly spot on to the 54mm (53.975) front and 36mm (35.56) rear. Wally I am not sure why yours would be different in Europe?
Thanks,
Adrian Pillow
Old January 19th 2005, 02:32
Yes, that is weird.
Weirder is that my early 944 M/C has 23 cast in into the M/C housing for front and 19 cast in for the rear. This would 'suggest' a 'perfect' 23,00 mm and a exact 19,00 mm.
I haven't taken it apart to verify this tho (and its on the car now)
Maybe there are more different sizes made to suit different countries...who knows?
Best regards,
Walter
Old January 19th 2005, 03:26
Richie's Avatar
Richie Richie is offline
Hello,
I have lent (sp?) my aluminum 944 Turbo MC to a friend but I hope to get it back one of these days.
Not sure anymore what it said on the outside but as soon as I get it back I'll take it apart and measure the pistons.
Cheers,
Richard
Old January 19th 2005, 18:13
judgie's Avatar
judgie judgie is offline
my 85 944na m/c is 23mm/19mm.why would the bores be 12/16" when origenaly from germany and would be metric.
the bias realy is a presonal thing , i run 85 na brakes all round and have the 23 to the rear and 19 to the front with 7x16 205/55/16 front and 8x16 225/50/16 back.works spot on for me.
cheers rob
