#61
This might be a good option as well:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW a 23mm 911 master fitted for the early 911s.
#63
Thanks for the post Matt
Someone else speaking sense to reinforce the important points. CU Jeremy
1302 RAt "GermanLook" |
#64
I assume your above statement is a 'misprint' ? Anyway, it doesn't seem to match up with Shad's mathematics, who I value greetly.I just fitted a 944 23/19mm mastercylinder and hope to inform you all the difference on brake bias as opposed to the stock 19/19mm m/c I had before. Reason for the switch was my terrible brake bias: too little back-side braking. Oh, I have now fitted the 23mm to the front, as it is stock in the 944, in order to lessen (!) the brake pressure to the front. Regards, Walter |
#65
Wally, your talking about changing to a split bore m/c from a m/c with a straight bore. This is how bias is changed
Ok, edit: m/c bore (when F = R, regardless of dia.) has no affect on bias..) I too have a lot of faith in Shad's calculations and written word, I bet he too would approximate your new bias to be 1.1.. Is there differences in bore sizes between NA 944 and 944T/951? Can anyone confirm? I've asked before.. My idea is to integrate the rear 15/16" piston from a 16v Golf m/c into a 'newly split bored' 13/16' m/c from the 8v Golf. The larger rear piston will push the front calipers and give a front/rear bias of 1.3:1 Similar to the Kerscher m/c :agree: Wally, my front tyres are only 95% the diameter of my rears, this will have a significant affect on my bias, bringing it close to the 1.6 of a 1980's 911. Which is a little too high for a Bug perhaps. I can't imagine anymore braking power in my Beetle. But I know there is some more there. My eyes already go May I suggest you experiment with an adjustable proportioning valve in your rear line. I plan to. Matt |
#66
here is the vw one that looks to be a bolt in.
there is another but the spacing on the mount holes is too far apart http://germanautoparts.com/Volkswage...it/Brake/137/5 these guys are usually the cheapest around and BEST quality. Normal price is 90-110.00 from what ive seen. |
#67
Reason for the switch was my terrible brake bias: too little back-side braking.< Could be because that VW MC is designed for drum brakes instead of the discs. When I converted the '66 Westi to discs all around Russell at Old Speed said they normally had to rebuild a drum MC to run the discs because there is some "feature" in there that pulls the fluid back to the MC instead of keeping a semi constant pressure residual like a disc MC will. Pardon my lack of technical experience here, just paraphrasing someone elses story ![]() I still contend that the 911 19/19 disc/disc MC is the way to go on a Beetle as it is setup very similar in weigh charactaristics and still similar in the disc brake setup (do not quote me on specifics though, but having rebuilt the 911 brake calipers before they are not way different fluid volume wize than 944 units). Seems to a degree as with anything that certain combos still need tested to determine the perfect conversion MC. For my IRS build-up (shhh, the pan should be here in two weeks, but do not tell the wife yet) I just bought a 19/19 911 MC to try out with the full 944 single pot setup.... Give me a year or two to post results
#68
May I apolagise to Wally, I muddled big-time, you have different (44/36) Brembo's to myself (40/36). I never questioned your math. I see exactly the same ratio's.
Matt
#69
Haha, no worries Matt
I seem to have the rather rare 944 turbo Cup brakes, which have more resemblence to 928 units (i.e. radially mounted up front).With your addition (F=R), it makes perfectly sense now. You see how easily we can misunderstand each other when we write things down, while thinking ahead already... Sorry Pillow, but the fact that the bug m/c was designed for rear drums has nothing to do with my bias problems with the huge Brembos I have now. I will report when the 03 is on the road again with the 23/19 alu 944 m/c. Regards, Walter |
#70
A drum mc has a residual pressure valve in, of around 10psi, this prevents the springs on the shoes retracting the wheel cylinders all the way in. On a disc car, if the MC is lower than the calipers, a 2psi residual pressure valve is sold to prevent the brake fluid draining back to the MC and retracting the pads from the discs. Both of these will cause the first press of the brakes to have excessive travel, if you were to pump the brakes the pedal would rise back up though Paul |
#71
I stand corrected after doing the math. The standard 944 N/A setup seems to be a good bias as compared with the early 911s 1.60 bias.
Just for the record 911 SCs (20.64 master with 48/42 calipers) had a 1.31 bias BUT used a rear preasure regulator that cut in at 33 bar. From "Porsche 911 Performance Handbook" by Bruce Anderson page 216. ... More to come, but I am thinking a 944 MC (23/20) with 911 "A" caliper front (48mm) and 944 rears (36mm) might work well with a 1.34 bias. Very rear heavy for a streeter though I think..? Thanks,
#72
Adrian
That combo sounds almost perfect I thought the CB kit was very similar in bias Keep us informed with how you get on. Cheers Jeremy
#73
Also my 944 rear isn't 36mm, but 38mm IIRC Differences in diameter quickly add up in a cross section (surface)! Good luck, Walter |
#74
'23' is more like '24' from 25.4(15/16") = 23.81mm, you knew that..
Matt |
#75
Good feedback guys!
![]() As for the 944 MC I got this one off a '87 944S model and it is cast into it "23" on one side and "20" on the other. Maybe this is different than the early 944 '83-'86 MCs? So the 23 is really 23.81, Jess that really does throw the numbers a bit ![]() Okay so the 19 or 20 will realy be either 19.05mm (12/16") or 20.64mm (13/16"). I went and measured the single piston 944 calipers (again from a 1987 944S) and I found them to be fairly spot on to the 54mm (53.975) front and 36mm (35.56) rear. Wally I am not sure why yours would be different in Europe? Thanks,
| Currently Active Users Viewing This Thread: 17 (0 members and 17 guests) | |
