Old January 19th 2005, 18:13
judgie's Avatar
judgie judgie is offline
my 85 944na m/c is 23mm/19mm.why would the bores be 12/16" when origenaly from germany and would be metric.
the bias realy is a presonal thing , i run 85 na brakes all round and have the 23 to the rear and 19 to the front with 7x16 205/55/16 front and 8x16 225/50/16 back.works spot on for me.
cheers rob
Old January 19th 2005, 18:32
Angelo Amato's Avatar
just fitted an audi a80 coupe one to the fasty..
pics
20.65mm dia. bore to run my setup comprising front audi coupe calipers and rear mk4 alloy calipers - cheap e-bay bargain new genuine ATE item ! - not bled them yet - hope it works ! straight bolt on fitment NO mods needed to mast cyl. only rod off brake pedal had to be lengthened 15mm. WHAT A FIT THOUGH !
Type 3 Fastback
Old January 19th 2005, 18:33
comparison pic..
amazing 30 years difference !
Type 3 Fastback
Old January 19th 2005, 20:11
MattKab's Avatar
MattKab MattKab is offline
Yeah, 30 years on and still imperial!
I bet the SAE are to blame for that
Old January 20th 2005, 11:35
Pillow's Avatar
Pillow Pillow is offline
This 23/20 versus 23/19 really pisses me off with 944 N/A brakes!
with a 23/20 (actual 23.81 / 20.64) = 1.69 bias (a little too high I think)
with a 23/19 (actual 23.81 / 19.05) = 1.44 bias (as staded before and a very good bias IMO!)
Arg!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old June 1st 2007, 07:30
1303R's Avatar
1303R 1303R is offline
i know this is an old thread but i'm trying to work out my brakes. i have n/a 944 fitted along with m/c. i find the brakes a lill front heavy. i work out the ratio to be 1.53. now if i changed the rear calipers to a 40mm piston the ratio would be 1.25. but what is the best set up for a street driven car? would i be better off having more rear brakes and maybe a proportioning limiter?
Old June 1st 2007, 07:45
1303R's Avatar
oh hang on. i get 1.44 ratio going off of 23.81 and 19.05 mm m/c sizes. is this deffiatly the right size bore?
