#31
@ Joe: good choise on the '75 03 Just took mine out for a first test drive and with the now installed Topline sway bar and their urethane front suspension bushings (the lot) and boy does it handle. It doesn't feel scary anymore to drive 180 km/h (which is a scary thought also actually) Regards, Walter |
#32
#33
Yeah, we've got to figure out a way to do stock (with modified suspensions) "challenge." I'm feeling like the 1303 is the way to go, but I can't help but want to see a real test. At this point though, if we don't do a test, you'll see me buy a 1303 with rack and pinion.
#34
A super has a lower centre of gravity anyway, so any weight advantage is cancelled out with reguards to cornering.
fastbug.net | FastTrack Dub Club "Straights are the boring bits that link corners together" |
#35
Man, now I feel really good about my car!
If its the Standard look you like you could get a 1302 and do the same thing. I like them both 1303 and 1302. I think 1302 is a better stock/GL car and a 1303 is a better all out custom/GL car. IMHO
#36
#38
like this one...
#39
I hate to be the technical guy again...but it would cool to get some real aero numbers on all the available spoilers. We'd just need to rent a wind tunnel, and have an assortment of spoilers (front ones too) anad find out just how much better they are from stock and from each other. Wow...I'm getting excited already. Well, there's something to ponder at least.
'71 1302 |
#40
Just get in touch with Lockheed here in town. See if they can fit it in after all the NASSCAR boys.
#41
'71 1302 |
#42
Im not really sure which would beat either, but you know that with a good driver, a car can do some amazing things. I drive a super, and i do love the way it corners, however i have also driven a standard and also love the way it handled. Of course i loved mine better, its mine and its on coilovers, but i think that a standard with coilovers would be a very nice mountain road machine.
If god had meant people to walk, whyd he invent cars? |
#43
Standards can handle pretty good. I just got a puma adjustable beam, and I seam welded the shock towers. Urethane shock bushings and kyb gr2's work good up front. I have a 17mm sway away irs sway bar in the rear, and a 17mm baR in the front. The beam is good as long as you keep it greased!
#44
ill keep you posted about our Aircooled Cup exploits as we are running a mixture of cars, standard right back to 55 and supers too. while we cant change the shape of out cars by adding large rear wings we will be fitting flat trays under the entire length and width of my oval, this was suggested by a friend who is currently employed by renault F1 team as an aerodynamic engineer. also whlie speaking to the guys that run the Uniroyal Fun Cup cars they said that the large rear wing make a big difference in cornering speeds, sometimes as much as 3 seconds on a large circuit like spa.
