I already shot it and you're right, what a smell. Well now the wife is even further away from the garage.
My tips are to: * thin it out per instructions and keep it very warm while using the extension tip to do the channels. I used the extension after spraying everything else, but it has to be very warm and well thinned to spray well. I got a big discharge from the channels later in the day under 80F heat. uke: * to do channels, insert as far as possible, then spray while pulling back. * use the normal sprayer to do everything you can as it sprays much better. * don't use this stuff until all your other work is done -- it's wax and will get all over you if you still need to do work in a treated area. * spray very sparingly. thicker is not better, just more of a mess. * keep a hot bucket of water available to keep the canister hot during application * wear gloves and dust mask as the stuff is kindof nasty Rust be gone, Bill |
