Old June 27th 2005, 12:03
rip's Avatar
rip rip is offline
empi, cb, and others usually sell two types of kits, with or without the parking brake. I'd make sure they are the samething as the without parking brake is about 130 USD cheaper.
also about the rear suspension, yea your missing one thing the IRS arm mount, these can be bought. Then you'd have to weld them in. And I'm not to sure on which spring plates to use. But other than some fabing to install it, it should be to hard depending on your skills.
So it made just be easier/cheaper to get a brake kit, but IRS is good also. Depending on the use of the trike IRS may be worth it.
Old June 29th 2005, 06:43
trevorbrady's Avatar
trevorbrady trevorbrady is offline
marcosgraveyard,
where in Ireland are you? I'm living in Portlaoise, working in Dublin.
Have you seen www.southernvolksfolks.com ?
check my website: http://homepage.eircom.net/~veewrx to see what I did with my rear brakes.
Old June 29th 2005, 10:38
marcosgraveyard marcosgraveyard is offline
Hi Trevor,
I'm in Longford Town, I've been searching the web for a while now and your site is the one I have been looking for, why couldn't I have found it earlier.
