Old July 9th 2005, 16:53
BuG60 BuG60 is offline
Can someone please tellm e what the benefit of haing a swing axle tranny is???
Ok, so I'm building this monster, its a 70 bug, i'm fitting a g60 engine, worked up to 300-325 hp / 340 ftlbwith the 24lb pulley, and 270 / 290 with the 14 lb pulley. I called up rancho trans. and asked some basic questions, and he told me that if I plan on running the bug in the 1/4, i'm MUCH better off with a swing axle. The car is IRS now, and am not too sure as to what exactly has to be done to the suspension, or any other part of the car to modify it to fit a swing axle trans. What benefits, or costs does the swing axle have over the IRS, and vice versa. I remember he was telling me the physical differences, and that its 15 lbs lighter, but is there any loss of handling, or ride feel?
This car IS meant for the strip, but its also meant for the street / nice sundays / local shows / what ever.....
Thanx for any info
-Mike
Old July 10th 2005, 00:50
jrinlv jrinlv is offline
Swing is great for goin straight, and it's stronger, and now that you say it, it's probably cheaper, but you will never get the performance for road control out of a Swing that you can get out of a well setup IRS. So if the strip is where you want to be go swing axle.
Old July 12th 2005, 01:13
but can an IRS still take the abuse of a 1/4 mile track like the swing axle can?
Old July 12th 2005, 08:33
it can take abuse. just not as much as the swing tranny.
Old July 12th 2005, 09:01
vujade's Avatar
vujade vujade is offline
I have talked with people that have said they have spend at least an
extra $1000 to make an irs as strong as a swing axle.
WinterJam 2010
Old July 13th 2005, 02:41
would you say that a swong axle equiped beetle has a much rougher ride, or that the grip in semi-hard turns would seriously take a Dive if I went swing, what about the fact thatI already have 944 trailng arms, in order to fit my 911 turbo 'big reds' brakes? Could I still convert to swing if I chose?
PS, Kinda leaning toward the swing, just cause i'm doing all this work, for a better 1/4, and if the consensus(sp?) is all the same for the swing, being that because of how its made, its better for the track, then I may just have to stick with a 5 speed swing, a worked berg 5 speed shifter, with 1-4 for track, and 5th for highwway speeds.
Old July 13th 2005, 14:34
MattKab's Avatar
MattKab MattKab is offline
A wheel that will clear those huge brakes will need an equally big tyre to transfer the energy. Swing-axle and the inherent negative camber doesn't like wide tyres as much as IRS.
Porsche brakes to swing-axle can still happen.
Matt
Old October 5th 2005, 01:01
kleinporsche kleinporsche is offline
Question What is it about Swing Axle?!
Why is it only good for going strait? A part from changing a SA to Irs, what coukd be done to get better hanling from a Swing Axle? porsche 550 spyder uses it! :agree:
Old November 20th 2005, 14:28
Aaaaanyone?! No comments?
Old November 20th 2005, 15:36
If you want to build a car that is mainly for the 1/4, then build a Callook, thats what they are really good at. Then go swing axle/ link pin, 2332 w 48IDA's and close ratio box. Why build a GLer that is only setup for the drag strip, your defeating the whole purpose of a German Looker, its ability to corner and brake like modern sports cars.
Old November 21st 2005, 06:58
Yes, exactly.
Plus: the fact that it says Porsche in front of a model number (550), doesn't neccessarily mean it has better suspension!
Another nice example: the Mc Pherson suspension that VW outfitted the 1302 models with in 1970 (!!): it took Porsche untill 1990 (that is 20 years later!!) before their aircooled rearmounted boxerengine model got the Mc pherson coil springs up front...
And I won't even start about the 924, 944 and 968 models that all still used basically the VW IRS suspension and those models were all street cars, not drag racers
Swing Axle has two great points for dragracing function wise: lighter and it renders less hp-loss.
Old November 22nd 2005, 20:48
bow's Avatar
bow bow is offline
if noone has mentioned this the swing-axel is much simpler and less things to break .w/irs there is many more parts to break hope this is a help
YEAH ITS GOT A HEMI
