to make things worse i found a pair of the same trailing arms at douglas valley
for 125 GBP each + 15 GBP for shipping in the uk. I thinck im just going to buy those as well and get the best combination Chris
Aircooled 4ever 1973 1303 going towards GL |
if you are converting from beetle rear brakes to 944. then the bearings are the same. you can use your bug CV's and, the bug stub axles too. the only different thing is the grease seal on the outer bearing retainer.
the prob is that i wont be using 944 brakes at all. i got 996 rotor all around with 930 finned calipers all around. and i got the stub axles for these arms as well. i dont mind at all paying for new CVs and bearings. but now im thinking over again, i ll have to measure every thing ie rotors before i buy anything else cos i need a parking brake
Have you tried Porsch-apart in Bury, Lancs?
+44 (0)7812 167547 martinandsonjaATf2sDOTcom |
I bought the bearings from Pelican parts in the US for $48USD, the local Porsche shop wanted $135AU each for them and a bearing supply place wanted $220AU each. I got CVs, boot, boot clips and clip tool sent to me with postage for $196AU. I would recommend anyone to use Pelican parts, very good service Why do you need a hub? I’ve heard that they are expensive, I think sway a way do them but they take a 930 CV CVs, aren’t they Kombi style CVs? Steve
![]() Quote:
English is a funny language, I suppose the stub axle is the thing with splines on it and the hub has the wheel nut studs in it. With the Kombi CVs, you can counter bore them so that they fit on the shaft, its OK if they slop a little in and out. Steve
