Old September 5th 2005, 01:39
Bruce2 Bruce2 is offline
No one can tell you your gear ratios because many different ratios were used. You have to read off the trans code, located forward of the diff on the right side, read from below the frame horn. Scrape away the gunk to read the code that is stamped into the case.
