Old September 22nd 2005, 15:57
ellobo ellobo is offline
No, It doesn't stiffen up the chassis. I would recommend the stiffening brace from eyeballengineering.
http://www.eyeball-engineering.net/F...stiffners.html
Or, you could fabricate your own. Here's one I did from 1 1/4 " square tubing...
The clips I got were from Vee Dub Parts Unlimited in Huntington Beach, Ca.
https://www.vwparts.net/Merchant2/me...y_Code=CHASSIS
Good Luck.
Old September 23rd 2005, 08:38
Bad bug's Avatar
Bad bug Bad bug is offline
Does the area where the clip sits see any loading on the chasis.
Old September 23rd 2005, 12:00
It shouldn't affect "loading". The clip is welded onto the torsion tube and fills the cut away in the frame horns.
But, When this breaks. The entire chassis will twist. That's the reason for the additional gussett and square tubing.
Old September 23rd 2005, 17:36
Bad bug's Avatar
Do you have any documented proof of any chasis twisting after this conversion. I intend to put a 2.0l t4 in my bug then maybe a 2.8l in the future .
Old September 23rd 2005, 18:49
Nope, nothing documented.....Just plenty of rewelding after good weekend of thrashing. So, go ahead and toss in a 2.0l t4 or a 2.8l or for that matter a V8....
Just do something like this first.....
Old September 26th 2005, 08:57
Bad bug's Avatar
I was thinking of running a kafer cup brace. I bought keith seume's book on vw beetle performance and it was stating that the kafer cup racers convert their swing axle cars to irs for racing. It wasn't sugested that their would be a problem.
