Old October 27th 2005, 22:04
volksdragon's Avatar
if you want something that doesn't rub on the front go with smartcar tires. they are a conti 175/55 R 15
they will have a 40 series look to them on the 5.5 rims. and the load rating will be fine for your car i beleive (not 100% sure but about 99%)
Old February 3rd 2006, 10:22
dubKustom's Avatar
dubKustom dubKustom is offline
Elev8_dude: How did it work out with your tires?
I have the exact same situation on my -69: stock beam (with adjusters, but at full height), CB 2,5" drop spindles and 15" diameter, 5,5" wide wheels with 185/60 tires. They have just enough room to rotate, but when I drive it it will certainly rub the fender at every bump or stop...
I don't want to narrow the beam, so I was thinking about two things: either getting a smaller tire (like 165/60 or something similar, maybe Smartcar?) and/or machining off some material on the inside of the wheel to move it inward.
Any other ideas anyone?
/Daniel, Gothenburg, Sweden
Type 1 -69 in Gothenburg, Sweden
70's German Look in the making
