Old November 16th 2005, 19:23
wahdubi wahdubi is offline
swop da diff
The early audi trans can be made to work in a beetle and all early and late share the same bolt pattern but only the early type to 80 if I remember correctly is worth the trouble. the later type trans has too many difficulties to make it a worth while proposition. It is a very strong trans and if you manage to hook up the shifter mechanism without going nuts then let me know please. Oh by the way the gear ratios are ok but 4th is a little low
