Very good choices i must admit. One issue for me though ( im going the same way for my street 1303)
The position of the front ing vents A: the J-sports racing bug has 2 cuts on the back side of the wings B: F40 used a huge vent on the back plane(vertical) of the front wings C: DTM Audis and 935 have vents on top of their front wings. From what i have read on the DTM cars is that the vents on top of the wing help the above the wing ( low pressure) get filled with the vented air from the wheel wells... D: the best i believe would be the 911 gt1 design I also agree with the front bottom closing every posible gap (air trap) Chris
Aircooled 4ever 1973 1303 going towards GL |
the DTM Audis and 935 have vents on top of their front wings. From what i have read on the DTM cars is that the vents on top of the wing help the above the wing ( low pressure) get filled with the vented air from the wheel wells...
yep thats why im going for the vents on top of the wings to try and "pump" air in to the rear wing,also its to try and have the low presure air in the wheel wells sucked out by the high presure air flowing across the top of the wing.vents must face to the rear to do this or will just force air into the wheel well. cheers rob
yeah thats what i meant
very nice bug ( you actualy partly realise my ideas )Im going to build two different kits for by 1303, one like a 935 and one like a gt1 with the fender extending all the way back ( both in 3d models first and then from alu)Chris
this is the sort of thing i had in mind
will just have to try and do it all before the season starts. cheers rob
Try and do something to the place around the transmission. Its a big gap that engulfs much air...In one of my designs im using a fake bottom and very square wheel wells for the back since rear wheels dont turn and their movement is minimal in a yaw manner.
Chris
cheers rob
In a few hours im flying back home so i could get some measurements. I believe that with "gently" you mean from the rear of the floor pan towards the back... otherwise it will be too low -the front clearence-(if it goes from the front to the rear directly)
Also one of my other considerations is: Would the side skirts be more effective if they have a small lip at a 90 degree angle towards the cetreline of the car? this would improve stractural rigidity and make it a bit more difficult for the side skirt to break if it touches the ground in a small radius u turn with high altitude difference...just a thought Another thing for you jugie and every other racing: in the case that the regulations permit it... Have you thought of putting ribs on the top-outer end of your wings? (like the K3 935) they are supposed to improve the flow over the end of the wing. (like the small lip that goes on top of the rear window, but on the longitudinal plane) it could improve the airflow to the rear fenders...and any air intake around there Chris
