Check the main page, GermanLook.com there's a good tech article on suspension. Which Porsche bars will work with vws. and sizes... :agree:
i think mine were either 27 or 27.5mm diameter and same length as a late beetle bar ( I hope). However it is important to consider that although a t-3 Squareback bar is 27mm, they may be softer due to different composition. I am only going to install the porsche torsion bars after i have my 17x9 wheels, because otherwise with to small a tire and too stiff of a rear suspension, you will run into oversteer problems.
biggest 944s were like 24-26 i believe.
type 3 squarebacks were 23mm fastys and notches are 21.5 or 22 i forgot....
www.subynotch.com |
The Type 3 squarebacks are 22.5mm. It doesn't say anything about fastbacks or Notchbacks. The best thing to do is read the article, it's very well put together.
