Old January 2nd 2006, 20:10
trevorbrady's Avatar
trevorbrady trevorbrady is offline
see my site for a 915 installed in a 1303 chassis. Centre of torsion tube cut out to facilitate the engine & gearbox being positioned further forward than stock...
http://homepage.eircom.net/~veewrx
Old January 2nd 2006, 21:56
BugaRu BugaRu is offline
Thanks for the info. Just trying to do my homework to see what I'm getting into before I go there.
You mates are really hacking and a cutting, must be determined to get those Porsche Boxes squeezed in those horns.
Steve you mentioned on your Website that you had to bend your linkage. I saw this used race shifter setup on ebay, maybe if afordable it could help you.
http://cgi.ebay.com/ebaymotors/Porsc...00073892QQrdZ1
Jon
Fast Cars, & Slow Women makes me drool..
Old January 3rd 2006, 05:12
915 gearbox installed
Hi,
just tried to upload a few pictures of a 915 in a 1303 chassis, but either the files were too big, or the pictures were not worth uploading anymore.
Wanted to show you, that a 915 can be placed in the same position as a bug´s gearbox without cutting the torsion tube out. With my conversion parts (nose cone, traverse front, axle flanges) it´s easy to manage. You can have a look on my site www.bugat5speed.de.
Do also have a 5-speed shifter for the 915 with very short shift ratios. It´s easy to install into bugs and is very exact to shift. Has very strong spring barrier inside against 5th and R-gear.
Can send some pictures by mail to those who give their mail-addresses.
Sorry that I can not show the pictures to all of you. Perhaps you can tell me what I´m doing wrong with my pictures (80 KB is not very much)
Cheers Martin info@bugat5speed.de
Old January 3rd 2006, 08:05
Hi BugaRu
Thats a nice shifter, I think I will stay with the stock one.
I cut my torsion bars for two reasons,
1 Moving weight forward for better distribution.
2 A STI motor with variable cams fitted to a G50 would have put the cam covers out near the rear bumper.
Old January 3rd 2006, 11:42
Does anyone know how much power a Porsche 915 Trans can hold. Also any idea of the R&P and 1-5th gearing?
Matrin... I checked out your Website but couldn't read German. By the way very nice and well done website.
Here is a link to one of my Websites. Nothing fancy, just shows some of my cars. Actually I need to spend some time on it and update it with newer pics and info. The 1966 Bug now has a new power plant.
http://www.bugaru.com/
Steve....
Is the STI engine being pushed backwards because of the added size of the Porsche Trans?
I'm using a STI Block but with SOHC's.. It makes the engine smaller. The pic attached "or should be attached?" This engine is rated at approx 325hp, on 8lbs of boost but I'll know better when I get it on the dyno.
Jon
Old January 3rd 2006, 16:27
mine is the same story as Steve. I cut the centre out of the torsion bar to shift the engine and gearbox forward. For me it was necessary as both the engine and gearbox are longer than the VW engine and gearbox. I want the whole assembly to fit under stock panels, i.e once the engine lid is closed nothing will be visible...
Old January 4th 2006, 04:31
ditto!
Old January 4th 2006, 08:02
Your correct, I needed to move the motor & trans forward because of the lenght of the overall package, if you look at the photo of my motor you can see the lump on the left rear cam cover. I have seen SOHC motors in bugs before they fit nicley.
I read an article on a Aussie Subaru STI here http://autospeed.drive.com.au/cms/A_1824/article.html
that had a few upgrades, nothing much, better exhaust, piggyback EFI controller etc and it made 195 kW (261.5 hp) at the 4 wheels. I will do these upgrades before I put car on the road and then see if I need anymore power after that.
PS If you cant open the file at Autopseed let me know.
Old January 4th 2006, 20:58
Steve.
Thanks for the link about the Tech tips on Subaru's. By the way it opened oK. I know what you mean about the cam covers on the DOHC engines. That's why I decided on using the SOHC heads on the STI block. Pic attached below.
Hey, I ment to tell you Nice Website, also great job on your 1972 Superbug.
Do you know Jak, and John from Auzzi who also have Subaru powered VW's. They both have great rides. Dang you Auzzi's just luv to wrench don't you?
Also any chance that you know what the gear ratios are for a G50 R&P and 1-5 ratios?
Jon
Subaru 2.5 with SOHC heads.
Old January 5th 2006, 05:30
Bad bug's Avatar
Bad bug Bad bug is offline
915 gearbox
Does anyone here know were i can get a 915 gearbox in the states.
Old January 28th 2006, 15:12
Axl's Avatar
Axl Axl is offline
Location: in a house somewhere in Calgary , Alberta , Canada
Originally Posted by BugaRu
Steve.
Jon
I know this is a transmission thread , but does anybody know the HP rating on the 2.5L engine ? How does it compare to the DOHC 2.0L turbo engine . Any help would be appreciated , as I am going to go with a Suby engine , and I want the most HP I can get . Axl .
