Old February 16th 2006, 18:48
speedy's Avatar
speedy speedy is offline
944 handbrake problem
put my rear arms on today and got it working fine only problem is when the handbrake is on there is about 1/4 an inch of movement backwards and forwards , seems to me to be the pads rocking on the inside of the bell , is this normal ? also when i take the handbrake off and spin the wheel it binds in one direction for a split second and then free's off , did not have time to investigate as i had to come to work , any idea's or even better a guide to setting the handbrake on the net somewere
cheers in advance
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old February 16th 2006, 22:25
What year arms? Bug cables, or Porsche and bug cables? How did you measure outside brake shoes to inside brake rotor? Do you have new e-brake cables?
Old February 16th 2006, 23:25
speedy's Avatar
the arms are 85 steel 944 , the cables are standard irs cables with vdub customs convertion pieces , as the shoes were brand new i set everything at the minimum , i have been on the pelican parts website and i may have not set the top adjuster correctly , i did not realize that the top adjuster was as critical as it apparently is, well 3 hours sleep in the morning and a day working on it should sort it out
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old February 17th 2006, 23:00
Oh, I thought you may of had '86 ali arms. I have '87 ali's with Vdub Engineering's conversion clips. I think there's a parts diagram on www.944online.com. I don't remember if Pelicans has one. Sorry, I can't help with your steel arms.
