What size pump are you using?
T4 2666 1303s |
I dont know what size it is but its not standard. Its a steel melling oil pump.
Cheers for the input guys |
What Oil Cooler?
I may be late on this on but I just wanted to know what the best way to run an external is oil cooler. I am thinking a 600mm from the front. Should I keep the stock cooler too, or run an adapter from the stock area? I have an external oil filter now taped into the case at this point. Should I run one of those sandwich adapters from my oil filter? Do I need a thermostat? I live in the Seattle and the car is 1303 with 1914cc. :shrug:
AJ |
