yes steve, you have about the most info out there w/ pics, i dont remember if i read this or not, but what year trans are you using?
Mike |
Hi,
G-50 is introduced and used first in 3.2 1987 911 None of the G-50 series was made of magnesium case. Short bellhousing are all 1987-89 units and some later ones. When 1990 C2 3.6 was introduced the G-50 was "officially called" G-64. Early 3.2 versus later 3.6 bellhousings are also shorter in the flywheel side as the later ones used the "dual mass" flywheel/clutch setup who is more thick than the earlier. 6 speed was an option on the first 993 (G50/21 & G50/20). Hydraylic clutch is standard on all years G-50. Most of them have a 9:31 R&P. What do you want to install beetle or bus ? In a beetle requires major modifications and if you want a 6spd is required to remove your frame horns completely and to scract built your engine mounts to "floating" type as vanagons and 911 used. Good luck
Jim Hunter 74 1303 (GL project) *SOLD* 73 1303 (GL project II) (VW T3s for sale.Panels, 2wd and Syncros) |
thanks for the reply Jim, you know the web.. full of missinformation, i dont remember where i read about the mag case, it was a long day of reading many websites...
its actuall going to be in a notchback (dream car from the first time i layed eyes many many years ago) and from the start i was pretty much counting on dumping the stock frame horns and doing some seroius amputation of the torsion housing, im planning coil-overs so it should be no bigger a deal than anything else lol could you recommend any one g50(g64) over another? /01 /02 /05 from reading the 05 is said to be the better of the bunch.. but ill refer to the top line of this reply any thoughts on the Getrag 6? Thanks Mike |
Hello Mike,
So you may have read that the first 915s has a mag case and later alluminium.I can recommend you some but what engine do you plan ? Displacement ? N/A or TBO ? Rgds, Jim
its either going to be a (2.0l) suby ej20t or the twin turbo version(much research has yet to be done on that topic), for sure a turbo, ill be shooting for the 350-400hp range. A turbo ecotec (2.2l) isnt out of the question either.
Thanks Mike |
Hi Mike,
Well, I suggest you to find a "short" bellhousing G50/00 , G50/01 If you can't find one the you can find more easily one from a 1990 C2 G50/03 who has also a ZF lsd 40%. Check classfieds at : www.pelicanbbs.com www.rennlist.com www.ebay.com Six speeders are very long. good luck
Why not try a 915 from a 930? Strong and much easier to fit in.
Thanks Jim you have been a great help :agree:
stin ighia' soo :haveadrin Mike |
